5 Signs of a Bad Rear Wheel Bearings
If you've recently noticed any unusual noises or other strange problems with your vehicle's wheels, you may be dealing with bad rear wheel bearings. Below are some of the most common signs of faulty rear wheel bearings.
1 - Extremely Worn-Out Tires
One common symptom of bad rear wheel bearings is extreme wear on your vehicle's tires. So, if your tires appear to be excessively worn, make sure to take your car to a mechanic, as your rear wheel bearings may be to blame.
2 - Problems Braking
tire on a black car
Braking problems are another telltale sign of bad rear wheel bearings. These problems usually manifest themselves in pulling your car to one side whenever you attempt to brake.
3 - Odd Noises
Abnormal noises are perhaps the most common sign of bad rear wheel bearings. Sounds that resemble scraping or grinding are particularly symptomatic of faulty wheel bearings. These noises often grow louder as your vehicle's speed increases.
4 - Steering Wheel Problems
steering wheel and dashboard
Steering wheel problems can also be symptomatic of faulty wheel bearings. If you've found that your vehicle's steering wheel has a tendency to wander, take the car to a mechanic and have the problem diagnosed, as your wheel bearings may be the underlying cause.
5 - Loose Wheels
If your car's wheels seem loose, bad wheel bearings may be the culprit. Regardless of the cause, loose wheels need to be looked at by a mechanic immediately.
