5 Soldering Station Safety Tips to Consider
You can easily make a soldering station that can be used for any type of work. Though you need to make sure you follow the correct safety procedures. Soldering uses high temperatures and there is potential for splattering and other accidents.  You also have concerns due to power and other issues to consider.
Use Heatproof Materials
Soldering uses high heat as what you are doing is to create joints or joining different metals together. Basically you are melting a metal onto another wire or metal to create a connection. In order to do this, the tip of the iron will reach temperatures of about 400 degrees Celsius. So this can produce very serious burns if it should touch your skin. You always want to put the soldering iron back on its stand as you can burn the table or workstation if you place it down on another surface, even if it is for a moment. Your safest procedure is to solder on a mat that is fire resistant.
Work in Ventilated Area
The fumes produced during soldering can be very irritating and it may not be enough to simply turn your head away from the fumes. Make sure you set up the soldering station in a well ventilated area and you may even need to set up a fan to get rid of the fumes. You will need to set up the ventilation and air circulation to you preference.
Go for Regular Maintenance
You want to make sure that the power cable does not wear out or become damaged. You also want to make sure that the iron is properly grounded and that you turn it off whenever you are not using it. You also want to give the soldering iron its own electrical socket as overloading a socket can blow fuses or cause other safety issues.
Protect Your Eyes
It is a good idea to wear protective eyewear when soldering as there can be some splatter. You also should wear high heat resistant gloves if you need to hold anything into place. If you don’t have gloves, use needle nose pliers to hold things in place. If you are going to do a lot of soldering then a heat resistant apron can also protect your clothing.
Wash Your Hands
You are suppose to wash your hands before eating and after using the bathroom and it is also important to wash your hands after soldering. Solder contains lead, which is toxic if it is absorbed through the skin or ingested somehow. You should make sure you wash your hands and workstation thoroughly to avoid a contamination or lead that may be present.
Don’t Forget
You may only have a small soldering task and decide it is too much trouble to use all the necessary safety precautions. However the consequences if something should go wrong can be severe so take the few extra minutes and make sure you are safe.
