5 Sump Pump Well Maintenance Tips
If your house or property is at all vulnerable to water damage, you’ll probably be familiar with the sump pump well and other parts of your sump pump. The sump pump is an appliance that sits in a basement or other low-lying areas, pumping water out of a well or reservoir and away from the structure of a building. This installation helps deal with storm water and runoff problems. Maintaining your sump pump well is part of overall maintenance for this device and something that can protect an investment in real estate from significant water damage if excessive runoff enters the building.
1. Test Your Pump Regularly
It makes sense to schedule frequent tests of your sump pump to make sure that it is running correctly. Many problems with a sump pump well can be observed if the well or reservoir doesn’t drain correctly. Often, experts recommend filling up the sump pump well area with water and letting the pump run to see if it is doing its job well.
2. Monitor the Power Source
If your pump is connected to the grid, you may not need to deal with power on a regular basis. However, if the pump is run on batteries, replacing these can be a crucial part of sump pump well maintenance to ensure accurate operation.
3. Check the Float
Many sump pump wells have a small float piece that helps the pump drain water in the right way. Checking the float can help you avoid problems with incorrect water routing due to a false message relayed to the pump.
4. Look for Any Erosion of the Well or Reservoir Wall
These days, manufacturers are coming out with new and innovative plastic sump pump well housings and jackets for a sump pump well. It’s always good to look at the sides of your sump pump well area and make sure that parts are not wearing away, causing dirt or debris to fall into the well.
5. Deal with Buildup
Over time, parts of a sump pump apparatus can get clogged by different kinds of small particles. Some experts recommend using white vinegar to run through the pipes and deal with any possible clogging in a sump pump setup. Those who have experience with these appliances generally recommend professionals for overall sump pump maintenance and unclogging of pipes.
Along with dealing with the sump pump well area, other parts of the sump pump need to be carefully monitored and evaluated for signs of damage or excessive wear. Property owners will want to make sure that they have the correct size of sump pump to route water away from the building. Any problems with a sump pump can lead to extensive water damage in a basement or another part of a house or property. Use the above tips and other good sump pump maintenance strategies to make sure your buildings are protected from stormwater and floods.
