5 Tips for Choosing a Sink Soap Dispenser
A sink soap dispenser is a very useful kitchen or bathroom accessory. Basically, this fixture makes washing more convenient and economical as soap is poured out in equal amounts and without spills.  Moreover, soap dispensers can also add style to your kitchen or bathroom sink. However, since there are so many types of dispensers available in the market today, it is important that you choose one carefully. Here are some important tips.
1. Buy One with Adequate Capacity
One of the most important things to consider when buying a sink soap dispenser is its capacity. This is especially vital if you have a big family. Before you choose, remember to factor in how many people will be using the dispenser and how often will the fixture be used. Even if there are only a handful of people who actually live in your home, a big dispenser is desirable if you always throw parties and expect visitors all the time. Make sure that your dispenser is big enough to accommodate the amount of soap that you need for at least a week.
2. Pick a Design that Offers Optimum Convenience
Soap dispensers come in various styles, designs and even shapes. With that in mind, you have to make sure that the sink soap dispenser you buy is appropriate for its intended users. As much as possible, choose one that will not complicate things in your kitchen or bathroom sink. Still, there are times when odd or complicated designs can be more advantageous than simple ones. Soap dispensers for kids often have funny and animated designs, but such styles are effective in promoting the habit of hand washing among the young ones.
3. Consider Where the Dispenser Will Be Placed
When buying a soap dispenser, do not forget to take into account the spot where you will put it. If you have a small sink, you can go for a wall-mounted dispenser so that it would not take up too much space on your sink. On the other hand, a free standing pump dispenser may be appropriate if you do not want to drill a hole in your kitchen or bathroom wall. Deck-mounted types are perfect for large sinks.
4. Be Mindful of the Type of Soap You Use
It is also a good idea to factor in the type of soap you use before you buy a soap dispenser. Although the most common types are designed for liquid soaps, you will also find dispensers that are suitable for powder and foam soaps.
5. Check the Material Used
Just like in other kitchen or bathroom accessories, the cheapest dispensers are not necessarily the best. The material used in making the dispenser can significantly affect its performance and durability. If you are on a tight budget, there is nothing wrong with buying a plastic dispenser for as long as it is made of high quality plastic. However, if you want elegant designs as well as strength, you can go for stainless steel, bronze or brass dispensers. A ceramic or frosted glass sink soap dispenser may be more appropriate if you have a classic kitchen or bathroom theme.
