5 Tips for Installing Adjustable Roof Brackets
Roof brackets are typically one-storey roof items, especially used on slanting roofs. Their ease of fitting and multi-purpose uses have made these popular items of purchase. Adjustable roof brackets require similar attention that one needs in installing non-adjustable roof brackets. However, you will be bestowed with more ease and comfort with the possibility of changing the width by 6 to 10 inches.
Tip 1: Inspecting your Roof
The most elementary part of the project involves making a thorough inspection of the slanting roof. Different roofs will require the orientation of the roof bracket and the requisite measurements to be different. Inspecting your roof for robust tiles is another important factor to note.
Tip 2: Getting Ready with the Tools
Installing a roof bracket requires some degree of professional help. The task needs some tools that you may not have used before. However, an adequate listing of them can help you when you travel to the construction materials shop. You can buy roof brackets from many specialist sellers. Specialist roof-bracket sellers are usually the sources from where you can pick up the entire set including a pry bar, hammer, nails, planking and a ladder. You will need to choose the nails carefully. As a beginner, you may need to gain some control over the slant of the roof and the ladder. As for the nails, you can buy both varieties like the 16 and 12-penny nails.
Tip 3: Standard Measurements of Bracket Boards
One must be sure enough to avoid the temptation of investing in lesser amounts of wood. Effectively, you will have one less plank, or planks too narrow. Both are threats to the user and can be fatal. Getting on one storey roofs is easy when you have a ladder, but staying stable can be difficult if the planks are less than 2 feet wide. The standard length of plank used for roofs is 6 feet.
Tip 4: Using the Right Impact and Pressure for Fixing the Brackets
Choosing the right nails depends on the amount of gripping you desire to produce on your tiled slanting roof. However, one must be careful about the robustness of the tiles so that they do not break under the clampers.
Tip 5: Spacing Between Each Roof Bracket
Installing roof brackets and placing planks can be as expensive as 500 dollars. Spacing between the roof brackets are thus extremely important and demands the use of measuring tape and accurate measurement. Make spacing measurements in accordance with the standard width, without considering the adjustable bits.
Also, remember that roof bracketing can be done at costs as low 100 dollars, especially if you invest in the right tools. Laying your hands on these tools require a pristine judgment of your roof bracketing needs. Follow these tips for a hassle-free installation of adjustable roof brackets.
