5 Tips for Installing Vinyl Fence Panels
Installing a vinyl fence, requires that you take precaution in installing the vinyl fence panels. There are things that you need to keep in mind in order for your fence to turn out like it should, and stay that way for as long as possible.
Read the 5 tips below to find out a little bit about what you should do, as well as what you should avoid when installing your vinyl fence panels.
Area of Work
The first thing you should pay attention to is where you decide to do your work. You will want to find an area that is clean, and free of debris. This will help in making sure that your panels aren't damaged or scratched in any way.
Not too Tight
Make sure you don't install your panels to tight together. Vinyl needs room to move. Vinyl will expand and change due to different types of weather. Installing the panels too tightly together, causes the vinyl to be restricted, which will result in your fence giving that ribbon affect. You will begin to see dips and bend in the panels.
Use a Level
The best thing you can do is to use a level to make sure that your panels are straight. Use it for the top line of the fences.
You will also want to make sure that they stay level after you have poured the concrete, as well as when the concrete is setting up.
One at a Time
Some home owners have tried to install their panels in a more quick manner. However, installing your panels more than one at a time, gives the panels a chance to become uneven, which in turn makes your hard work kind of a waste.
As you install your panels one at a time, you will also want to stop your work frequently, using your level each time, to make sure each panel is installed straight.
The panels are very easily movable when you are working on installing them all. Making sure they are level throughout your process will make things a whole lot easier and faster for you.
Don't Paint
Vinyl was made to be pretty much maintenance free. That is why it is so popular amongst home owners today. In fact, it would be surprising if you didn't decide on vinyl because of it's maintenance free ways.
Because vinyl is made to be maintenance free, it does not need, nor does it accept, paint. Now, there are down sides and up sides to this. The down side is you are stuck with whatever color you decided on in the beginning. There are options to choose from in color, but you will not be changing the color once the fence it up.
However, on the plus side, if you can't paint your fence, neither can anyone else. If your fence is vandalized or accidentally spotted up with paint, a dab of cleaner will take it right off.
Following some good directionand remembering these tips will ensure a properly installed fence. Just remember the old saying; if you are going to do it, do it right.
