5 Tips for Planning to Add a Wall in Your Home 5 Tips for Planning to Add a Wall in Your Home
Planning to add wall structures to your home can seem like a very challenging project to embark upon. However, there are many simple tips you can employ to complete this type of task which will make the process much easier. Take your time to think about what you are doing and make sure you do not make any basic errors.
1 - Planning
Planning is vital when considering whether to add a new wall to a house. You need to plan carefully where your new wall is going to go because it cannot simply be erected anywhere. A good tip is to draw a detailed plan of the room the new wall is going to into. Also, draw detailed plans for the other rooms that are going to be affected and include measurements for the recalculated size of each room. Find the ceiling joists in each room and mark them with a permanent pen or piece of paper as they are vital in new wall addition jobs. You will always need to work around the existing structure of a room.
2 - Do Not Cut Corners
Adding a wall to your home is a job that will not allow you to cut corners. Spend at least 60 minutes making sure you have covered every angle. You will need to manage your time in a professional manner. Plan for the possibility of needing extra hands to help you work and set a budget for the entire job. A good tip is to write an action plan and show it to a professional or someone with wall addition experience. They will point out the flaws which can be correct before work begins.
3 - Tools and Materials
Do not go head first into a project without considering the tools and materials you will need or already have. It is a good idea to use the same materials that form the basis of existing walls in your home. Shop around to get the best deals on tools and materials. Having the right tools and materials at your disposal will make the job of adding a wall much easier.
Make a list of all the tools you already have. You will need hammers, cutting tools, a drill and a set of general use screwdrivers. These are all standard tools for adding a wall.
4 - The Wall
Do not fall into the trap of thinking that any new dry wall has to be the exact size of the wall you are creating. You should leave a small margin for error and any gaps can be filled in with compound at a later stage. Allow for this by measuring the area your new wall will be constructed. Use a large tape measure and write down precise measurements. Take 1 inch from each side of the wall to allow for comfortable installation. An inch and a half of compound will set to about 1 inch in size after drying.
5 - Ceiling Joists
You must find the current location of the ceiling joists in the room you are planning to add a new wall to. They will be needed to attach fasteners and additional 2 by 4 pieces of wood to. You must not weaken any ceiling joists because they are linked to the structural integrity of rooms and walls.
