5 Tips for Uncolgging a Toilet Drain
When the toilet drain becomes clogged it is sometimes quite a chore to get the system flowing again. With the toilet drain clogged, you will not be able to use it or risk severe water damage as it flows over the seat while the tank empties itself. There are many different myths and crazy techniques for unclogging a toilet drain. However, very few of these actually work. Before you call the plumber to help you with the toilet drain clog, here are some tips that you can use to get the drain unclogged yourself.
Plunge First before Anything Else
The first thing that you should do is to reach for the toilet plunger when there is a toilet drain clog. The plunger should have a large enough suction that will cover the drain hole at the bottom of the bowl completely. There should also be a ring on the rubber suction cup that will form a little seal over the drain hole. Push straight down and wait a second before you bring the handle back up. Do not lift the plunger up away from the drain hole. Keep a tight connection. Continue to plunge until you feel the water start to go. If you do not, then you will need to try something different.
Use a Toilet Drain Snake
A drain snake is a simple tool that is basically a handle attached to a spring with the help of a springy tube. You can feed this tube down to the clog in the drain and turn the handle. While the handle is turning it is also turning the spring that is at the bottom of the snake. This will then drill into the clog. Once you have turned the handle a few times you can pull up the snake. This should dislodge some of the clog and cause it to collapse. If not, then repeat a few times.
Use Dish Soap and Hot Water
One of the different strategies of unclogging a toilet drain that does work is the combination of regular dish soap and very hot water. Use a 1/2 cup of dish detergent and pour it into the bowl. Let it sit there for about 20 minutes. After the time has elapsed pour in a couple quarts of boiling hot water. This combination will work with organic type of clogs. If there is something that has been forced into the toilet drain you will have to continue with the plunger.
Do Not Pour Hot Water into Cold Porcelain Bowl
If you are going to use the boiling water method of unclogging your toilet, you will want to add a little bit of warm water first to the mix. This will bring the temperature of the bowl up a little before adding the really hot water. If you do not, there is a chance that the boiling hot water will be a shock to the porcelain and cause it to split.
Easy With Plunger
Plunging a clogged toilet is sometimes the only way to unclog the drain. However, if you plunge away like a jackhammer you can damage the pipes from the force of the suction and water flow. Take it easy and only plunge up to 20 times each try.
