5 Tips for Vinyl Gutter Installation
Vinyl gutter installation is relatively easy compared to the traditional gutters used in old houses. They come in kits that you can just snap together and fasten along the edges of your roof. They are also easier to replace and you can change just small damaged pieces instead of replacing and re-installing entire sections. Despite its easy installation, below are some additional tips in order to maximize its effectiveness and make the gutter installation process more worthwhile.
1. Durability
Before installing vinyl gutters you have to make sure that are strong enough to withstand the load of rain that comes your way. If you expect heavy rains during the whole year, it is recommended that you get the most heavy-duty gutters possible. Read the information about the product carefully and determine if they will hold up for the intended use. Also check the physical quality of the gutter, such as thickness and quality of the material used when considering your gutter installation.
2. Supports
You should also correctly determine the optimal spacing of the supports of the gutter. Things that you have to take into consideration for gutter installation are the severity of the weather conditions in your area and the length of the gutters. The worse the weather and the longer the gutters, the more supports you need. They are usually spaced every 10 to 14 inches apart, but if you have a small gutter, you may want to position them closer together.
3. Reducing Cost
Although vinyl gutters are cheaper than their metal counterparts, it’s still not a bad idea to try to save on gutter costs. Gutter installation can balloon out of control sometimes and you should do everything possible to keep the cost down. Take accurate measurements at home so you only buy the materials that you need. Also, determine what places on your home you need the gutters to be installed. You may not need to install gutters on the entire house, so you can save some money this way. Finally, just use the necessary components when and where needed. For example, you don’t have to install downspouts everywhere. Determine the flow of the water and see where you really need them.
4. Weather Conditions
Consider the weather conditions in your area for gutter installation. Extreme weather conditions may not be suitable for vinyl gutters. Extremely cold weather may expand and contract the gutters, causing them to break more easily. Extremely hot weather may in turn warp the material and eventually lead to breakage. Even tremendously windy conditions can damage the brackets and supports of the gutters. Make sure to buy the appropriate gutters for the climate in your area.
5. Vinyl Gutter Shape
There are lots of shapes and designs available for vinyl gutters and determining the best one for your home is recommended in order to maximize its effectiveness. You can choose between seamless and sectional gutters. Seamless gutters are recommended if rains are pretty heavy in your area since they are not prone to leaking. Sectional gutters on the other hand are better if you want to install them yourself. Another consideration is using U-shaped or K-shaped vinyl types. U-shaped gutters are perfect for cold climates so you can readily replace the pieces when they crack due to extreme cold. K-shaped gutters are for warmer climates, which help keep the water cool inside the gutter. These are some common shapes that you may want to consider during your gutter installation project.
