5 Uses for Epoxy Paint
Epoxy paint is a special type of paint that has a number of potential uses. Epoxy paint is one of the toughest and most durable paint materials that is available on the market today. Here are a number of potential uses that epoxy paint would work well for.
1. Bathrooms
One of the most popular potential uses for epoxy paint is putting it in the bathroom. Epoxy paint is very durable and resistant to moisture. Therefore, it makes the perfect choice for a bathroom application. Bathrooms typically have a high amount of water and steam in them. During a hot shower, there is a good chance that moisture will get on the walls. If you are dealing with a paint that does not deal well with this moisture content, you could be in trouble. Therefore, using epoxy paint in the bathroom will allow you to avoid any water damage or damage from air moisture.
2. Saunas
Another potential use of epoxy paint is in a sauna room. A sauna is not like your typical room. Any paint it is on the wall in a sauna will have to be able to stand up to extremely high temperatures and a high amount of moisture as well. This makes the epoxy one of the best paint choices available for this scenario. Over the years, epoxy paint has proven to be a good choice for this type of application and has stood up well to the abuse. Using another type of paint will result in cracking and peeling and the need to repaint it often.
3. Pool Rooms
A pool room makes another great potential place to use the epoxy paint. Pool rooms that are indoors, are going to generate a fair amount of moisture in the air. Therefore, you need something on the walls that can stand up to the high moisture content and not be negatively affected. In this application, epoxy paint makes a lot of sense.
4. Garage Floors
The garage is an area that has a lot going on in it most of the time. People are walking on the floor constantly and cars are driving in and out on it. Therefore, if you are going to put something on the floor, you need something that can take a lot of impact and abuse. Epoxy paint is the perfect solution for this scenario. If you drop a tool or something else heavy on the floor, most of the time it will not damage the paint or require any touch-up. Epoxy paint has a great ability to withstand abrasion and heavy things that are rolling across it.
5. Commercial Applications
In addition to many residential uses, epoxy paint is commonly used in commercial applications as well. Putting it on the walls in a commercial building will give you a painted surface that can stand up to a lot of wear and tear. In a commercial application, you will have people constantly shuffling in and out and a great deal of traffic to contend with. Epoxy paint can be a great solution in this case.
