5 Ways to Kill Springtails in Your Home 5 Ways to Kill Springtails in Your Home
Springtails typically live in decrepit and humid areas. You can find them nesting behind damp walls, in the kitchen, and even in the bathroom. Their presence can easily become a nuisance in your place because of their sheer number. So, here are some tips on how you can eliminate springtails if they ever turn out in large numbers to infest your home.
1. Improve Home Ventilation
If you want to deal with springtails for good or prevent them from relocating to your place, you need to minimize the moisture that accumulates in your home. The best way to do this is by enhancing air circulation. Also, make sure that you install appropriate insulation and roof protection to keep both excess heat and rainwater out. Excess heat and water are the key elements that can cause moisture inside. By preventing damp areas from occurring, you will not have an ideal environment for springtails to thrive in.
2. Pour Vinegar Directly on Springtails
The high acidity content of vinegar can burn and kill springtails and that alone can prevent these pests from propagating or migrating into your place. If you are dealing with a massive infestation, this solution can be a bit costly because you may need to pour vinegar several times before you can see the effects.
3. Wash Affected Areas with Detergent and Water
If you do not want to spend a lot on vinegar, your next best option is to wash the infested areas using detergent and water. All you need to do is mix soap and water until bubbles or froth appears. Then, simply apply the mixture on the affected areas. The soap solution will burn and even drown large numbers of springtails. For larger droves of springtails or for best results, make sure to repeat the process several times on each infested area.
4. Use Bleach
Springtails are a very resilient type of infestation and using soap solution or vinegar can only do so much. If you want a stronger and faster acting remedy, you can opt to use bleach. Since this is a corrosive solution, it can easily eliminate very large numbers of these pests. But few people, if any, like the smell of bleach. So, if you cannot stand the smell of this kind of solution, you may not be able to use it against the pests.
5. Apply Insecticide or Hire an Exterminator
If ordinary home remedies do not work, your next move is to use insecticides. These are widely available in home improvement or even grocery stores and they come in liquid concentrates, granules, or easy-spray cans. Since insecticides are essentially poisonous, they can instantly eliminate large colonies of springtails and other pests. But because of their lethal ingredients, you need to be very careful when applying them and follow any instructions to the letter.
If everything else fails, your final option is to call in a professional and have your place fumigated. Here, the exterminator will use very powerful types of chemicals designed to kill all types of pests, including springtails.
