5 Wood Graining Tools Explained
Wood graining is a beautiful technique used to make walls and other surfaces appear to be the solid wood of your choice. There are a number of tools involved in this faux finish, and each one works a little different then the rest. Here is a brief overview of the five most important tools used to produce this interesting effect.
1 – Flogging Brush
A flogging brush is a thick paintbrush with extra long bristles, commonly made of horse hair. When used to paint your surface in long strokes, it produces an effect that looks like the capillaries of a finely finished piece of wood. Use a flogging brush to paint on your first layer of wood colored paint, after you have primers the surface.
2 – Check Roller
If your goal is to simulate a wood with a more porous look, such as oak, birch or mahogany, a check roller is a crucial tool. It’s thin checks move separately as you use the metal roller, creating an uneven woven effect that matches that of your favorite wood. Use this tool over a wet surface, recently painting over your base color.
3 – Check Combs
Unlike the check roller, check combs produce a more controlled effect. Available in a variety of different styles and materials, choosing either a set with varying teeth sizes, or a triangular check comb will allow you to literally comb in a grain on your wet paint. To determine whether you want thicker or thinner teeth, longer or shorter ones, talk to the expert where you are buying your paints about the specific wood you wish to simulate on your surface.
4 – Overgrainers
These fine paintbrush “pencils” add an extra touch to your wood graining faux finish. Often coming in sets, you choose the brush of your choice and lightly drag them through your color glazes to create fine lines and “flaws” that would be found in a real wood surface.
5 – Wood Graining Rocker
The rocker is the most important tool to have when creating a wood graining finish. This rubber tool produces the ultimate wood grain texture by being slid and rocked through your wet finish. It’s surface is made like a wood grain stamp, some complete with knot holes, and by streaking it through you have perfect control of producing the inconsistent look and texture of a wood grain. You may consider using several different rockers for the job of wood graining to produce grains and knots with more variety or you can simply use one, changing your speed, sides, and how and how often you rock the tool across the wet surface.
Depending on the wood you wish to copy, you may need all of these tools or just one or two. The amount of detail that goes in to making your surface as realistic as possible is completely up to you. Being creative and choosing the colors and methods you think will look best is key to creating a wood graining faux finish you are proud of.
