6 Advantages of a Flexible Exhaust Pipe
When do-it-yourselfers are looking at replacing part of an exhaust system on a vehicle, they may be wondering about flexible exhaust pipe and how this kind of product can help make renovation of an engine system easier. There are a number of good points to using flexible exhaust pipe for exhaust systems. Knowing about all of the various options for materials and installations will assist when it comes to rigging up an improved diesel or regular gas engine, whether it’s a car or truck, or a boat or other specialty vehicle or a piece of industrial equipment.
1. Various Grades
Flexible exhaust pipe and tubing comes in a variety of different “grades” of materials that can make a difference in how the final result will stand up to corrosive elements. Builders can get galvanized or aluminum options, or a higher-grade stainless steel pipe that offers flexibility combined with strength and durability.
2. Rust Resistant
Some of the higher grades of flexible exhaust piping are extremely rust resistant, making them good options for a variety of projects that will stay attached to a vehicle for a long time. Look for “salt water resistant” pipes for boats or marine vehicles.
3. Chemical Resistant
Some types of flexible exhaust tubing are known to withstand corrosive chemicals and help to avoid chemical buildup. The positioning of some exhaust pipes can also help with the possibility of chemical buildup in some cases.
4. Good for Tough Welds
One primary use of flexible exhaust pipes is in situations when the existing system doesn’t provide a good opportunity for welding rigid pieces into an exhaust line. Trying to match parts and pipes can be extremely difficult, and a slightly flexible pipe can help make the fit.
5. Space Efficient Exhaust Systems
According to some professionals, flexible exhaust pipes are commonly used to make exhaust systems less bulky and a lot lighter. These kinds of systems are used on many family vehicles and other specialty cars, as well as larger rides. The flexible pipe can give an engineer more options on optimal design for this critical vehicle system that is getting so much attention as world leaders promote rimming emissions and keeping engines running at top efficiency.
6. Absorbing Engine Vibration
According to some of the professionals who work with these kinds of materials, a flexible exhaust pipe can, in some setups, help to deal with excessive vibration in an engine compartment.
Look at all of the above advantages to working with some of the newer flexible exhaust products on the market when it’s time to make sure that an overall exhaust system is doing its work well, routing exhaust gases out and away from a vehicle and curbing emissions. Taking on these projects yourself requires a thorough knowledge of how exhaust systems work, and overall safety guidelines for changing an existing exhaust system. Some kinds of exhaust changes are actually illegal, so be sure to do thorough research before tackling an exhaust problem on any vehicle.
