6 Advantages of Using HID Fog Lights
High intensity discharge (HID) fog lights are one of the latest lighting technologies available for automobiles. These lights do not use the metal filament that halogen lights use. Instead, HID lights use a capsule of xenon gas to produce light. The lights also contain a metal halide and electrical arc set between 2 electrodes inside the lamp. A high voltage spark of electricity is created by a ballast which ignites the gas to produce a distinct bright bluish light. However, you can also get purple and pure white light with the upgrade varieties of HID lights. Below are 6 advantages that come with these lights.
1.   Energy Efficient
HID lights utilize less power to produce more light than halogen lights. Lumens produced from a 35 watt HID light are about 3 times the lumens produced from a 55 watt halogen light. This makes HID lights an energy efficient choice due to the lower power consumption.
2.   Eco-Friendly
The lower energy utilized to produce light results in less carbon dioxide emissions from the vehicle into the atmosphere. This helps to reduce the degree of environmental pollution caused by cars. The lights also produce less heat than standard lights which makes for a more stable environment.
3.   Greater Illumination
HID lights produce greater illumination than other lights. They yield extremely bright light which is similar to natural daylight. It covers about 70 percent of the road. This contributes to higher visibility as you drive which is vital for road safety. It also gives a higher level of confidence behind the wheel. Reaction time to obstacles you may encounter on the roads is not only faster but more accurate. This is a boost for safety not just for you but other road users.
4.   Better Distribution of Light
HID fog lights distribute light more evenly than other lights. This is because once ignited, the xenon produces extremely bright light, as much as 3 to 5 times brighter than halogen lamps. The higher intensity of light helps to create a more uniform distribution of light which enhances visibility.
5.   Durable
HID lights have much higher longevity than other lights. In most cases, the lights will last throughout the life of the vehicle. They typically have a service life of 2,000 hours compared to 500 to 1,000 hours for halogen lights. This is partly because HID lights do not use a filament which tends to deteriorate with time. Most models of HID fog lights are also manufactured with a high impact resistance.  They can withstand more vibrations and shocks without any damage. This makes the lights a cost-effective choice to install in your vehicle.
6.   Extended Battery Life
Like most people, you may on occasion, forget to turn off your fog lights. With HID lights, you needn’t worry about your car battery losing life should you forget to turn off your lights. The lower energy consumption of the lights prevents depletion of battery energy which helps to sustain the life of your battery.
