6 Advantages of Using Oil Deck Stain
Oil deck stain is a very popular choice for those who want to stain their decks or other woodwork. It’s been around a long time, and proved itself over the years. Oil deck stain wouldn’t have lasted so long if it didn’t do a very good job. There are a number of advantages to using oil deck stain that put it ahead of the competition.
Advantage #1 -  Easy to Apply
Oil deck stains does on easily and smoothly. You can work it into the wood with a brush, and clean it simply and quickly with mineral spirits. That makes the job go faster, although you should be aware that the stain does take longer to cure than other types.
Advantage #2 - Long Lasting
Where other types of deck stain can wear easily, oil deck stain is long lasting, and you can expect a lifespan of several years from an application. That makes it very good value, but cost is the least important factor. You want a stain that will do its job properly, and stay looking as good as it did when you first put it down.
The last thing you need is to be touching things up every few months. With oil deck stain, you won’t need to do that. Unlike other stains, oil deck stain won’t peel, which looks unsightly and ruins all the work you’ve put in on your deck.
Advantage #3 - Penetration
Unlike other types of deck stain, oil deck stain offers deep penetration into the wood. This helps the stain keep its color well, and also protects the wood more, as the stain doesn’t just coat the surface. Because of that, the stain is long-lasting.
Given one good application, you’ll find the wood thoroughly protected, both inside and out, which stops the formation of mold on the wood, as long as you buy a stain that contains algaecides and mildewcides.
Advantage #4 - Looks
There’s no comparison with the look of oil deck stain. When it’s first dried, there a shine to it that can’t be beaten, although this will depend on the type of finish you buy.
Inevitably, that can’t remain indefinitely, as the deck will receive a lot of wear and tear, but initially it looks better than any other type of stain. It lets the beauty of the wood show through properly, and gives a richness to it that’s extremely enticing.
Advantage #5 - Moisture Repellent
No other stain repels moisture like an oil deck stain. That’s due to the oil in the stain, and it’s why you’ll see water beading on an oil deck stain. That, in turn, translates to a longer life for the deck, and more time before you need to apply a new coat of stain to the deck.
Advantage #6 - Cost
They say that you get what you pay for, and with oil deck stain, that’s perfectly true. It costs more than latex stain, but the lifespan on oil deck stain means that it works out cheaper over the years. It also takes less oil deck stain to cover the wood properly, and the ease of application means less labor time.
