6 Fence Panel Painting Tips
Painting fence panels can be a very relaxing pastime for one person and a time consuming drudge for another. Still, it is one of those jobs that has to be done. Here are some tips to make it easier.
Brushing the Fence
If the fence is not a huge length it makes sense to brush it down to get rid of surface dust. This dust not only absorbs the paint but blocks the brush or roller. Even a huge fence should have bird droppings washed or scraped off. A major benefit of cleaning the fence is that you get to take a closer look at it. This will give you the chance to fix any loose boards or panels, and repair any breaks.
Roller
A rag roller has a good area of coverage and will speed you through the job. If you have a wheel barrow you will be able to organize the roller tray so that it is held firmly right where you want it. You can also carry as much spare paint for refills as you need – not to mention some refreshments.
Extendable Handle
To paint panels that are hard to get at you can use an extendable handle to give you some extra reach. This could save damaging plants or getting caught up in thorn bushes. The handle will also help you to paint behind plants and shrubs growing up against the fence. You can use a large flattened cardboard box slid behind the plants to pull the plants away from the fence while you paint behind them.
Sprayers
Paint sprayers can speed up the fence painting. It is always best to use the proper product for paint spraying fences. There are popular economies like thinning indoor paint so that it will go through a sprayer, but these often mean that the finish will not last so well. It might be obvious, but don’t spray into the wind! Open wood work or trellis should only be painted with a brush. Using a roller can waste a lot of paint as it gets squeezed out by the trellis pattern.
Weather
It stands to reason that you would not paint your fence in a down pour, but it is just as fruitless to paint your fence in full sunlight. The heat of the sun will make the paint dry before it has had time to soak into the wood and add the protection you were hoping for.
Stain
Do not rely on stain to protect the wood. Stain is simply a way of adding color to the wood.
Cut Ends
Pay special attention to the ends of the timber that makes up your fence. The ends are the most difficult to get at and yet they are the most vulnerable part of your fence. It is well worth the effort to go over the fence with a small brush to make sure that the ends of every piece of timber are adequately covered.
Paint your fence properly and you won’t have to do it so often.
