6 Inground Fiberglass Pool Maintenance Tips
Inground fiberglass pools are one of the most popular choices for homeowners. The pool consists of a large fiberglass shell-like structure which arrives ready to be sunk into the ground. Some designs combine concrete or some other material with the fiberglass. The ground must then be excavated to accommodate the pool. It may be supported by sand and concrete. Installation is usually faster than that entailed for concrete pools. The pools are available in various styles and shapes. Fiberglass pools are also a good choice for residential purposes, as they have lower maintenance requirements compared to vinyl and concrete pools. Below are 6 tips to help you care for your pool.
1.   Clean Regularly
Leaves, bugs and other debris tend to gather on the pool waters frequently. The occurrence of this is even higher if you have a mature garden with several trees. If left unattended, it contributes to unhygienic pool waters. A dirty pool also looses its attractiveness. It is a good idea to maintain a regular cleaning schedule. This way, your pool can constantly reflect a clean and attractive appearance. A skimming net and telescopic pole come in handy. Attach the pole to the net so that you can easily scoop the dirt from all areas of the pool. You may want to use a leaf vacuum to suck in dirt from the pool bottom.
2.   Cleaning Products
It is best to avoid harsh cleansers when you clean your pool. These can damage the fiberglass and necessitate costly repairs. Harsh cleansers also alter the chemical balance of your pool. Use cleansers that are specifically formulated for fiberglass pool maintenance. Avoid brushes with stiff bristles, as these are likely to leave scratches on your pool walls.
3.   Stains
These may occur if the metal levels in the water exceed the ideal levels. Excessive iron is indicated by reddish-brown stains, while bluish-green stains indicate high amounts of copper. You may also spot gray stains which are caused by excessive magnesium. A metal chelating agent can help you reduce the incidence of stains. Apply this in your pool according to the instructions every 2 weeks.
4.   Pool Filter
It is a good idea to turn on your pool filter after each session of swimming is completed. This helps to collect the debris that is stirred up while the pool is in use. Allow the filter to run for 6 to 8 hours daily so that the water circulates properly. It also helps to keep the pool chemicals well balanced.
5.   Proper Chemical Balance
This is vital for effective pool service. It is best to check the balance on a daily basis. Ideally, the pH level should fall between 7.2 and 7.6. Alkalinity should range between 100 and 150 parts per million and chlorine level should be at 3.0 per million. Where necessary, add the chemicals to attain the proper balance.
6.   Pool Cover
No doubt, your pool is unlikely to be used during certain times. Purchase a solar cover to keep out dirt and debris. This will reduce on the maintenance work. It also helps the pool to maintain the right temperature.
