6 Kitchen Sink Hose Installation Tips 6 Kitchen Sink Hose Installation Tips
A kitchen sink hose is a very useful gadget. It allows you to spray water to rinse a pan or dishes. You can also use it for washing vegetables prior to cooking. Luckily, it’s not difficult to install a kitchen sink hose. As far as plumbing tasks go, it’s one of the easiest. You don’t need many tools, and the chances are you’ll already have what you need.
Tip #1 - Easy Fitting
Most sinks come with a fitting that allows you to install a kitchen sink hose. You'll need to find and open it to fit a kitchen sink hose. Be aware that it's only attached to the sink by a series of tabs that are under the sink.
Tip #2 - Univeral Hose
There might be a specific kitchen sink hose that’s made for your model of kitchen sink. That’s not always going to be the case, however. You should know that you’ll do just as well with a universal kitchen sink hose, as the fitting is standard. You’ll find that they’re inexpensive items. In some cases, hoses do wear out, but usually it's just the nozzle part that will need to be replaced. As a general rule, you won’t often have to replace the entire hose.
Tip #3 - Water Containment
You always need to remember to turn off the water at the mains before starting any plumbing work. To prevent any spraying, be certain to run both hot and cold faucets until no more water comes through, and then turn them off again. Turning them off will prevent spraying when you turn the water back on.
Tip #4 - Using Rubber Collars
Before putting the kitchen sink hose in place, install the rubber collar on the hole in the kitchen sink. It's a simple matter of doing it as the right step in the process. Don't leave it out, as it makes a good rest for the sprayer, keeping it in place when not in use and improving the look of the sink.
Tip #5 - Water Lines
The beauty of a kitchen sink hose installation is that there's very little plumbing involved. Select the right place for the fitting on the cold water pipe. By using a fitting that pierces the pipe as it screws in, you won't even need any special tools for the job, which is an advantage for anyone.
Make sure you follow the steps in the installation instructions as they're written. Remember, they're that way for a reason, and trying to bypass one will only cause you to have to go back and retrace your steps.
Tip #6 - Teflon Tape
Use Teflon tape on the male fitting that attaches to the hose. This will prevent any drips and give a much firmer seal. Just wrap it around the threads a couple of time before screwing on the hose. Using it can prevent many problems, and you'll find it useful on all your plumbing jobs.
