6 Pinto Bean Care Tips
Standard gardening tools
Pinto beans
Fertilizer
Lattice, trellis or wire mesh and post
Compost, gypsum and pea gravel (optional for soil with poor drainage)
Growing pinto beans is fairly simple to do, but not foolproof. There are precautions you can take to make sure you have a healthy and bountiful crop. The pinto bean is really just a mature and dried green bean. These legumes can be grown from the dried beans you buy in the store. They are extremely nutritious, as they have high amounts of fiber and protein.
Pinto beans like a dry climate and can be grown in hot areas, but they are particular about their soil. Below are some tips to make sure you have a successful pinto bean harvest.
Step 1 - Choose a Spot and Prepare the Soil
Make sure the area you choose gets plenty of sunlight, as pinto beans thrive with the light. Pinto beans need to be planted in soil that has good drainage. If you think your soil may not have proper drainage, you can do certain things to improve it. Add compost and gypsum to your soil. This will attract worms to the area, and worms act as natural aerators for the soil. If your soil is especially dense, consider adding a little coarse sand or pea gravel.
Step 2 - When to Plant
Pinto beans can be planted after the last frost of the year. Once the cold weather is passed and the ground has warmed, it is safe to plant the beans.
Step 3 - How to Water Your Growing Plant
During the growing season, take care not to keep the plants too wet. If they have too much moisture, they run the risk of becoming diseased. The best thing is to let the ground dry up slightly between waterings.
Step 4 - Nourish the Pinto Bean Plant
During the entire growing process, make sure to keep the area weed free. Weeds will kill your plants if you don't keep them at bay. Weeds steal the moisture and nutrients plants need to grow, and that leaves them vulnerable to disease and malnourishment, which will lessen your chances at a good crop.
When the plants are about 6 inches tall, work some fertilizer into the ground around your plants. If you have planted rows of pinto beans, go down the sides of each row with the fertilizer.
Step 5 - Support Your Pinto Beans
Pinto beans are a climbing plant, and if they get too heavy, they will bend to the ground and not produce much. You can help by giving the beans something to climb. You can use lattice, a trellis (depending on the number of plants), or you can build a fence for your beans to climb. Start by pounding a heavy stake into the end of each row. Attach wire mesh to one of the stakes, run along the row of beans and attach to the stake at the other end. This well help them grow and produce the most fruit.
Step 6 - Harvest on Time
The beans can be picked at most stages of development, as long as you can see beans in the pods and they don't become too mature.
