6 Rental Tips when Considering a Concrete Saw 6 Rental Tips when Considering a Concrete Saw
If you’re considering renting a concrete saw for a DIY project, there are a number of factors to think about. Renting equipment for a job means you’ll be working with used equipment. You have to be sure it’s in good condition and capable of performing up to the standard you desire. If you don’t know what you’re doing, you could end up paying more money if the concrete saw ends up damaged.
1. Saw Size
The first thing is to make sure that the concrete saw is powerful enough for the job. If it’s not, you’re going to struggle to do the work required and you can end up damaging the tool or burning out the motor. You will need to go in with a good idea of the capacity of saw you require, and this inevitably means some research. Don’t automatically believe a rental store clerk who tells you the concrete saw is powerful enough.
2. Saw Condition
Before you agree on the rental, inspect the saw thoroughly to make sure it’s in good condition. It’s especially important to check the water feed. If it's blocked or not working properly, the blade won’t be cooled. This can destroy the blade and the motor of the concrete saw.
When you inspect the saw, make sure that any damage is noted in full on all copies of the rental agreement. This means you won’t end up being charged for it when you return the concrete saw.
3. Operation
If you’ve never used a concrete saw before, you’re not going to know how to use one properly. Have the tool rental store show you all safety features and give you thorough instruction. This will cut down on the number of mistakes you make, especially those that could damage the concrete saw.
4. Blade
Make sure that you have the right blade for the job and that you know how to fit it correctly. Trying to cut concrete with a blade designed for asphalt or using a blade that isn’t deep enough for the cut you want to make is particularly dangerous. You could damage or even destroy the blade, and you’ll have to pay for that when you return the equipment.
5. Rental Agreement
Before you sign on the dotted line to rent your concrete saw, take time to read the rental agreement thoroughly. It lists your responsibilities with the equipment, including your liabilities. This is very important. Some places will be relatively generous, while others can be very strict on the terms. You will have to return the equipment by a certain time and in a certain condition. Knowing the details can end up saving you money in the longer-term.
6. Price
Any major city is going to have a number of places that offer tool rental, including concrete saw hire. They all want your business, so it's inevitable that they’ll be competitive in terms of service and price. Expect rental costs to be similar, although it's always worth shopping around. Check the rental conditions when you’re undertaking your comparison shopping.
