6 Safety Tips for a Rooftop Wind Turbine 6 Safety Tips for a Rooftop Wind Turbine
For many people looking for alternative power means, a rooftop wind turbine is an alternative that is becoming more popular. With wind turbines popping up all over the country on top of hillsides and mountains, it is only the next step in the progression to see them mounted on top of roofs. With this type of application there is some inherent dangers involved. Anytime something is attached to the top of a roof, there must be some safety precautions taken in order to ensure protection against personal injury, or damage to the roof. Here are a few tips to think about when using a rooftop wind turbine.
1 - Proximity to Trees and Wires
Anytime you are looking at putting something on your roof, you should find out if there is enough available clearance for the object. A wind turbine will require a lot of clearance on all sides of the turbine blades as they spin around. If there are any trees near the home, or branches that have overgrown, you can either trim them back, or transplant them in another area.
2 - Use Guide Wires
As the rooftop wind turbine sits on top of your roof, bolts alone are not going to be able to hold the entire assembly upright. The whole assembly is going to have a considerable amount of vibration due to the turbine spinning. Adding to the pressure is the wind that will cause the body of the turbine to sway. Use strong cables, that are mounted to sections of your roof, to help take some of the pressure off the mounting bolts.
3 - Keep as Close to Peak as Possible
Having a wind turbine closer to your eaves is going to put it at an awkward position. It will have one section of supporting legs much longer than the others. You should attach the rooftop wind turbine to the exact center of your roof, situated in the center of the peak, so that there is an equal amount of weight distribution on all of the supporting legs, roof trusses and foundation walls.
4 - Use Notices
To help visitors, and people near your home, know that there is a rooftop wind turbine on your home, you should put out notices as people enter your driveway. This will not only notify people, but is also recommended by insurance companies and the manufacturer.
5 - Ground Turbine
One of the problems associated with the wind turbine is the fact that it can attract lightning during a storm. You will want to make sure that the turbine structure is grounded so that the lightning does not damage it, or cause problems to the electrical components of your home.
6 - Reinforce Roof
Before you can begin to place the wind turbine onto your roof there are extensive structural changes that need to be made first. Because of the added weight, the vibrations and the force caused by the wind, you will need to reinforce the entire structure. Doubled roof trusses, reinforced sheathing, and even a reinforced bottom sill near your foundation. This will all help to support the added pressure that the entire house will be under.
