6 Steps of Wood Floor Leveling
Level
6 foot 2x4 straight edge
3/4 inch plywood
Screws
Leveling compound
Wood putty
Power sander
Meter tape
Nails
Screwdriver
Hammer
Colored chalk or carpenters markers
Wood varnish or paint
Brush
Clean rag
Broom
Wood floor leveling is one of the many home maintenance tasks that one should do. There is still no way that one can choose to live with floors that have unwanted sags or slopes. Doing so would only lead to more damage. Aside from this, an unmaintained wood floor could always drag down your home’s aesthetic appeal. It might be tempting to install a new floor on top of the present subfloor. However, you should make sure that the surface that would eventually go underneath is at level and even. To help you in the matter, here are some steps to wood floor leveling.
Step 1 – Clean the Floor Area
Use a clean rag and broom to clean the entire wood area before venturing on the next steps. Doing so would let you easily get rid of debris that can interfere with wood leveling procedures. Sand the areas that need to be repaired. Examine the floor and mark the damages with colored chalk.
Step 2 – Attach the Wood Sheathing
Prepare to attach the wood sheathing. Position it on top edge of your floor’s joists. Fasten it securely. Solid wood joists may have differences in height and width depending on the way that your previous contractor chose them. As such, it is better to measure them prior to the shopping of materials.
Step 3- Drive in Nails and Screws as Necessary
Strengthen the floor by driving down corkscrew nails in areas that get heavy foor traffic. As wood tends to contract or expands, the nails get loose. As such, screw will help prevent the floor from squeaking. Also note that screws must be long enough to go down the floor joists by at least 1 ¼ inches deep.
Step 4 – Identify the Highest Level of the Floor
Using a level and 2x4 straight edge, check the highest level of your floor. Put the straight edge so you could swing it to a full 360 degree. This would let you locate the highest point. Use sanderto trim it down.
Step 5 – Apply Leveling Compound
As you have previously damaged areas, inspect them to see if there are any dips. Apply a leveling compound to make the areas even.
Step 6 – Get a New Plywood Subfloor
Even out the existing subfloor by installing a new ¾ inch plywood subfloor. Make sure that the wooden joists could still accommodate the new subfloor on top of the hardwood flooring. Adjust the thickness of the plywood as necessary.  You can choose to use a less thicker plywood.
Step 7 – Inspect for Loose Screws and Nails
Check to see if there are loose nails or screws. Sand the area again and varnish or paint as desired.
