6 Tips for Cleaning Shower Wall Panels
1-2 hours
Beginner
- $0-70
If you're looking for an easy yet stylish option for your shower, consider shower wall panels. They are easy to clean and hypo-allergenic. They don't require extensive cleaning, but thinking that they don't need to be cleaned at all is a big mistake. Here are six tips on how to keep them clean.
Clean Regularly
Because shower wall panels are smooth , you may think you don't need to do anything to keep them clean. That is a common misconception. Once a week, use a light bathroom cleaner that is appropriate for the shower panels. Not taking the time to wipe the shower wall panels allows the unsightly buildup of soap scum and dirt.
Ammonia
Ammonia is a powerful cleaning agent; therefore, you need to dilute it in order to protect your shower wall panels. Mix 1-part ammonia with 2-parts water in a spray bottle. Apply it liberally on your shower panels, then wipe it away a soft cloth.
WARNING: Ammonia can stain cotton clothing, so be sure to work gloves you don't mind damaging when you work with ammonia. Ammonia is also toxic to breathe in, so make sure the bathroom is well-ventilated and put on a face mask (and to avoid getting it in your eyes) safety glasses before you start working.
Vinegar
Vinegar is the most natural solution for cleaning shower wall panels. You can either dilute the vinegar or apply it unadulterated to your shower wall panels. Test the vinegar on a small patch to make sure it does not damage the wall panels.
Dish Soap
You can always use the dish soap. Dilute it with water before applying to the shower wall panels. Then rinse the panels with water and wipe them dry.
Things to Avoid
If you have not cleaned you shower wall panels for a while and there are hard stains, do not be tempted to use an abrasive cleaning product. The wall panels are durable, but some heavy duty bathroom cleaners and bleaches could ruin the shower. The same goes for the accessories; stick to soft cloths and sponges. Do not use Brillo pads or steel wool.
Prevention
The atmospheric conditions of your bathroom affect the cleanliness of your shower wall panels. Keep the bathroom ventilated, as air flow will help prevent mildew from growing. If you have a bathroom fan, remember to turn it on after showering. Mildew loves dark places; keep the bathroom lights on as long as possible. If you find yourself cleaning the shower wall panels too often, think about installing a fan or heat lamp.
