6 Tips for Cracked Leather Shoe Repair
Saddle soap
Old rags
Newspaper
Mink oil
Matching shoe cream
Carrying out shoe leather repair is a lot more economical than simply throwing cracked shoes away or buying a new pair. Repairing cracks in leather shoes is a simple, inexpensive, and fun way to extend the life of your shoes. Prevention is often the better cure and regular polishing or buffing will help minimize the chances of cracks ever occurring in leather shoes. If cracks have already appeared, follow these easy shoe leather repair steps and you will soon be stepping out with confidence.
1. Use Saddle Soap
One useful tip in repairing leather shoes is to wash them with saddle soap first. Saddle soap can be bought from most equestrian stores. Rub the soap generously into the cracks while using as little water as possible. Shoe leather repairs work best when the shoes are as dry as possible.
2. Avoid Heat and Air Dry
Avoid applying heat to dry a shoe quickly because the cracks will become more severe. Place the leather shoes outside, free from any direct sunlight and rain, and allow them to dry with natural air.
3. Stuff the Shoe to Maintain its Shape
Leather shoes that are often cleaned and repaired have a tendency to lose their shape. This can be easily avoided by stuffing old rags or newspaper into the shoe while you perform the repair.
4. Use Mink Oil
Applying mink oil to the cracks that have appeared in the leather will penetrate deep into the crevices and rehydrate the dry leather. Although people tend to be unaware of using mink oil when repairing leather shoes, it is an effective way to give some much needed moisture back to crevices and cracks. Always let the shoes dry before applying the shoe cream.
5. Make Sure to Have a Proper Color Match
One useful tip is to take the shoes to a shoe or hardware store that sells leather shoe cream. This way you will be able to determine a good color match. Once you have found an appropriate color, apply the shoe cream generously to the leather, paying particular attention to the cracks and crevices.
6. Equal Buffing
Having oddly matched shoes is not the desired outcome of anyone performing a shoe leather repair job. Polishing and then buffing a shoe for a longer period or with greater pressure than the other shoe will result in one shoe being a lot shinier than the other. To avoid this mismatch, time how long you buff the first shoe. Usually, three to four minutes is an adequate amount of time to spend polishing a shoe. Repeat it on the other foot and check colors against each other. You may need to buff up one of the shoes a little more to get a perfect matching pair.
