6 Unique Basement Window Treatments
If you have a basement, you might be looking for a way to use basement window treatments to make the windows look much bigger. Basement windows often appear small and make the whole room look both unappealing and dingy.
These special window treatments can improve the look of your basement windows significantly. Basement windows are often much wider than they are high, looking more like something out of a prison than a dream home. This article explains the 6 most common basement window treatments.
Mirrors
Mirrors are very useful at making your room look much bigger. They also bounce light around the room, which makes it much easier to create a friendly and welcoming space. Mirrors can be strategically placed opposite windows to reflect light all around the room and create interest in certain features. Although using mirrors isn't technically a window treatment, it is an effective way of improving the look of your windows and making the best of the light you have available.
Mirrors can also be applied directly below or above windows to make the window look much bigger than it actually is. It is much more effective if the mirror panels are cut to the same size as the window panes.
Window Film
Window film makes your basement much more private. Using this film will reduce the amount of light available in the room, which could be an issue if you have a small window.
Blinds
Blinds can also be used in a basement for privacy. Using light color blinds so as not to look intimidating. You can also spray the blinds with paint for a custom look.
Curtains
Curtains are a fantastic way to provide warmth to your room. If your basement feels cold and damp, it can often be remedied with heavy fabric curtains, such as velvet.
Consider the length of the curtains. Most basements have very small windows, making it tempting to use small curtains; however, using a longer curtain can create the illusion of bigger windows.
When choosing curtains, stick to light and airy colors to make your house look more appealing. A heavy pattern could be overwhelming.
Valances
Valances or swags add extra appeal to curtains. They are made from the same fabric that you used for the curtain, but they are designed to cover the top of the curtain. It is a purely decorative window covering. Valances are ideal for adding extra height to a short window.
Shutters
Another great way to create the illusion of large windows is to install fake shutters just below the real window. These doors will remain shut, although the space could be use for storage if desired. If installed properly, these shutters will make it appear as if the window is much bigger than it really is.
