7 Advantages of Fiberglass Decking
a light purple deck
Fiberglass decking is a great choice for outdoor installations. It is made from extremely fine glass fibers combined with resins to produce high-quality construction materials. Fiberglass has become one of the most popular materials for both indoor and outdoor installations. It isn’t too hard to see why, given its many benefits. Below are 7 advantages of decks constructed with fiberglass.
1. Resilience
Fiberglass is one of the strongest construction materials available on the market. It undergoes a rigorous manufacturing process that produces a tensile material suitable for outdoor installations. Due to its high resilience, it creates decking with excellent dimensional stability which enhances the functionality of your deck.
2. Durable
The non-porous nature of fiberglass gives it an extremely high resistance to moisture. Your deck will not warp or rot due to the effects of water. Fiberglass copes well with extreme hot and cold weather conditions. Prolonged exposure to sunlight doesn’t affect the color appearance because the color is ingrained right through the material. Fiberglass doesn’t easily crack or dent due to the impact the way wood does. This helps to extend the life span of your deck.
3. Ease of Installation
The lightweight nature of fiberglass contributes to the ease of assembly. You need not enlist much extra labor to help you construct your deck. The material can be carried with minimum effort which saves you on labor costs during installation. Fiberglass is also one of the more flexible materials to work with. You can attach fasteners and drive in nails without too much trouble, which speeds up installation.
4. Affordable
Fiberglass is one of the most affordable construction materials on the market. Given its high resilience and durability, a fiberglass deck is a good value for the money. You can plan to construct your deck with whatever design within a reasonable budget.
5. Increases Your Home Value
With fiberglass, you enjoy a virtually unlimited color selection and a wide range of design possibilities. This makes it an excellent choice for residential outdoor installations. A well-installed fiberglass deck enhances your lifestyle and improves the appearance of your home. It also adds to the resale value of your property.
6. Low Maintenance
Not much work is necessary to keep your fiberglass deck in good shape. It doesn’t require special cleaning materials. Simply vacuum the surface to get rid of dust and light debris. Occasionally, you may want to use a damp mop to wipe away dirt and soil. A more thorough wash can be done once a week with warm water and a mild detergent. Fortunately, fiberglass doesn’t develop stains easily due to its non-porous nature. This makes it even easier to care for fiberglass decking. It is also resistant to damage by insects which reduces the maintenance work required.
7. Eco-Friendly
Fiberglass is 100 percent recyclable. This makes it an eco-friendly choice if you have environmental concerns. The utilization of fiberglass in construction helps to ease pressure on natural resources. Some of these resources are already in danger of depletion due to the rapid rate of exploitation. A fiberglass deck helps you to contribute towards sustainable resource management.
