7 Advantages of Owning Faux Wood Blinds
Faux wood blinds are usually made of vinyl or a blend of real wood and vinyl. An increasing number of homeowners are considering the real benefits of faux wood and recognizing their potential in home decoration. Window blinds in a home play an important role in its overall appearance and environment.
Traditionally, wood has been the material of choice as far as blinds are concerned. However, environmental issues, high prices and the need for proper care have forced buyers to look at the virtues of faux wood blinds.
1. Cheaper than Wood
The reasonable price of faux wood is what attracts many buyers. It costs a fraction of the price you would have to pay for real wood blinds. You can decorate many more windows at the same price as a few wood blinds and still expect the same level of attractiveness and beauty from the blinds.
2. Resistant to Moisture
Wood blinds have a major disadvantage when it comes to moisture and humidity causing it to warp, swell and expand. Over time, the protective finish wears off the wood, leaving it exposed to environmental conditions. Excessive heat and sunlight can also damage wood causing it to fade. Faux wood blinds, on the other hand have a much higher degree of resistance to moisture and heat.
3. Easy to Clean
Faux wood blinds are easier to clean and manage as compared to wood blinds. You can wipe them clean or give them a quick rinse with a hose, if needed. Faux wood blinds are totally resistant to water.
4. Long-lasting and Durable
Given their high resistance to humidity and heat, faux wood blinds last for a longer time than wood blinds. They also last in much better shape. Once you install these blinds, they will last for many years. They can also be refinished if needed.
5. Available in Many Varieties and Colors
Faux wood blinds are available in many different colors and sizes. You can also have blinds custom made for your needs. This adds a great deal of flexibility to your decorating options.
6. Environmentally Friendly and Recyclable
Faux wood blinds are actually much more environmentally friendly than real wood. By purchasing faux wood blinds, you are contributing to a reduction in the number of trees being cut down. You can also purchase recycled blinds and make an even more eco-friendly decision. These blinds are also fully recyclable, so you can help reduce the amount of refuse in landfills.
7. Attractive in Appearance
Though faux wood blinds have so many benefits to offer, they are cheaper than wood and still offer the same look as real wood. Many people have difficulty distinguishing between real and faux wood blinds, so your guests do not have to know that your blinds are not real wood.
Drawbacks of Faux Wood Blinds
Fans of real wood blinds argue that nothing can provide the authentic feel and warmth of real wood. Also, wood blinds are lighter and require fewer slats. They can also be recycled and are available in more choices and finishes than the faux versions.
