7 Drill Press Safety Tips 7 Drill Press Safety Tips
A drill press is a wonderful tool to have in your workshop, but like all tools, it can be dangerous if you don’t take adequate precautions. Drill presses are very versatile, but can also be very powerful. You'll need to be constantly aware of the dangers when using one.
Tip #1 - On/Off Switch
It’s vital to know exactly where the on/off switch is on your drill press. That way, if there’s a problem, you can just reach over and flip the switch without have to search for it. It could be the difference between a minor and a major injury. Make sure your drill press is securely mounted and placed on an even floor, otherwise it could tip over when you’re using it.
Tip #2 - Safety Glasses
Whenever you’re working in your shop, you should always wear safety glasses. Nonetheless, it’s even more important when using a drill press. Chips or swarf can fly up into your face. If you’re not wearing safety glasses, these can easily cause eye injuries.
Tip #3 - Keep your Shop Clean
You should always keep your shop well-swept. This isn’t just for neatness, but for safety purposes as well. Keep the work surface of your drill press clean and make sure you always clear away all debris created, especially if you’re working with metal. Chips on the floor can penetrate the soles of your shoes and possibly cut your feet.
Tip #4 - Clothing and Hair
You should never wear loose clothing when working with your drill press. Similarly, if you’re wear
