7 Propane Fire Pit Safety Tips
A propane fire pit is an outdoor structure that uses propane gas as fuel. The popularity of fire pits is increasing tremendously. These structures enable you to enjoy the outdoors even on cold days or nights. However, to maximize safety and reduce the number of accidents, there are several safety tips every user must be aware of. In the case of propane fire pits, you must be even more cautious, because the presence of combustible gas can greatly improve the impact of an accident.
1 – Choose a Safe Installation Spot
When you install your propane fire pit, choose a spot that is at least 10 feet away from your home and other outdoor structures. Make sure there are no pipes underneath and no electric wires overhead. Also keep foliage and trees a safe distance away from the fire pit.
2 – Keep a Fire Extinguisher Handy
In the event of a fire, you must know what steps to take. Prompt action can avert a tragedy. Before using the propane fire pit, familiarize yourself with its functioning and all the parts. You must know how to turn off the gas supply and control a fire that gets out of hand. Keep a fire extinguisher handy and make sure it is not expired and that everybody in your home knows how to use it. You can also manage most fires by pouring water or dumping sand on the blaze.
3 – Keep Area Free of Clutter
Keeping objects close to the fire pit increases chances of ignition and flames. Such flames can quickly get out of control and start a blaze. Keep the area around the fire pit clean and clear at all times. Never keep combustible substances or liquids in the vicinity. Never leave children unattended in the vicinity of a fire pit.
4 – Clean Burners and Pipes Regularly
A blocked or dirty burner or pipe can cause a buildup of gas, which can be very dangerous. Periodically, you must clean out these parts. This is especially important if you are using the fire pit after a gap of several months. Sometimes you may find insects nesting inside the burners, contributing to a blockage.
5 – Check for Leaks
Before turning on the propane fire pit, rule out any leaks. Check all the connections and valves for any signs of a leak. If you discover one, turn off the gas supply immediately and tighten the connections.
6 – Shut off Gas Supply in Case of Emergency
In case of an emergency, the first step to take is to turn off the supply of propane. If the fire is so big that it cuts off your access to the propane supply, try to dampen it by pouring water or putting sand on it. Then try again. If you are unable to do this, call the fire department immediately.
7 – Never Add Gasoline, Paper or Fuel
A propane fire pit does not require any starters or accelerators to increase the strength of the flame. Never pour gasoline into the fire pit or add paper, trash or combustible matter. Use a screen to prevent the spread of sparks.
