7 Safety Precautions when Using Crimping Pliers
Crimping pliers are tools that are widely used in jewelry making, sealing bottles and vials, and for creating tags or impressions on metal. These handheld tools give a firm grip on objects and crimp or leave impressions on the surface after the work is complete. Even though these are very basic and simple tools, you must follow a few safety precautions when using crimping pliers.
1. Work on a Stable Surface
Before commencing any work, it is important to do a quick survey of the work area to ensure that there are no obstacles that you might trip on and fall. When you have a tool in hand, the imminent danger from a fall is greatly increased. Clear your work area before you begin and ensure that people in your vicinity also know that you are working, so you can be free of distractions or interference.
2. Avoid Working in Dark or Unlit Areas
It is also equally important to work in clearly lit areas, so that you can minimize the chances of accidental injury. If you need corrective lenses, make sure that you wear them when working. Avoid consuming medicines that make you lethargic if you have to work with tools soon after. Also avoid alcohol consumption to ensure stability and good coordination.
3. Keep Children away from the Work Area
Children must be kept away from any work area that has sharp or heavy tools and instruments. In addition to the danger they are at themselves, children can also be a source of distraction, thereby increasing the chances of accidents.
4. Wear Safety Glasses and Gloves
To protect your eyes from any particles of splinters, always wear good quality safety glasses when you work with crimping pliers. Wear gloves to prevent nicks, scrapes and calluses on your hands.
5. Only Use Crimping Pliers for the Intended Purpose
Avoid using crimping pliers to turn screws or bolts. Never use them in place of a wrench or screwdriver. Avoid using the crimping end or the handle to strike hard surfaces, as this may damage the tool and also cause injury. Never use a damaged tool under any circumstances. If the handle is cracked, have it repaired or replace the tool before you use it again.
6. Use Bigger Pliers for Heavier Jobs
Whenever you use a set of crimping pliers, be certain that they are appropriately sized for the job at hand. By using a small set of pliers for large or excessively hard objects or wires, you can permanently damage the tool. Avoid altering the tool in any way if you want to use it on bigger objects or to get better control. Instead, alter the size of the tool you use.
7. Keep Crimping Pliers in an Enclosed Location
Protect your crimping pliers from rain, snow and excessive heat. This will prevent problems such as rust and deformation of the tool. Maintain your crimping pliers according to provided instructions and oil them once in a while to increase lubrication and ease of use.
