7 Tips for Choosing a Rain Barrel
When it comes to deciding on a rain barrel for your home, many different things must be considered before reaching a final decision. It is definitely not something that can be bought on a whim. You will need to sit down and do some planning before you hit the store. By forging a plan, you will be able to get the best barrel to suit your needs. If you are not sure on the size that you should be using, taking a look at your last water bill during the peak months is a great way to determine how much water is used. From this information, you can determine its size.
1. Choose the Proper Materials
One of the first things that you need to do is make sure the water you are collecting is safe. Your roofing materials and or gutters can make the water unsafe. You do not want to collect water if it has any type of lead-based paint, which is sometimes used in gutters. It is also important to take into consideration the type of shingles that are on your roof as well as tar and gravel. The safety of the water should be the number one concern.
2. How Much Water to Collect
Your next step should be to figure out just how much water you need to collect. This will help you decide on the size you need and the type that you may want to consider putting in. As stated earlier, seeing how much water you use during peak months can be a big help with that decision process so that you get the right rain barrel.
3. Allocating Space
Figure out how much space you have to allocate to your new venture so that you can make a proper decision on whether you want a system that is above or below ground.
4. Ensure a Tight Lid
You need to make sure that your system has a tightly sealed lid in order to avoid invasion from unwelcome guests. This would include mosquitoes, wandering animals and even algae.
5. Choose UV Protected Materials
Choose a material that is UV protected and be sure to have a mesh screen so that you can keep much of the debris floating around out of your water supply.
6. Overflow System
Consider having an overflow system so that excess water cannot damage your property and cause flooding.
7. Final Touches
There are other things that you should consider doing in addition to a rain barrel. This includes installing a filtration system for the water to keep it clean as well as the distribution of the water using pumps. You may even want to consider how to kill bacteria by using UV lights before it has a chance to become dangerous.
You can see that there are many different things that you need to take into consideration before you decide to get started on your project. Once you have your game plan into effect, you can take action and then start deciding on just how you want to build it.
