7 Tips for Using a Spiral Saw to Cut Ceramic Tile
A spiral saw is a great way to cut though wooden material, drywalls, and ceramic tiles. The spiral saw uses a sideway cutting mechanism to cut holes in any relatively thin material used in constructions. It is mechanically powered and is able to cut through thin materials with accuracy and speed. Perhaps the most common brand of spiral saws is the RotoZip. It is a product of the RotoZip Tool Corporation. The tool is basically designed to make cut-outs in drywalls. However, the tool proves to be efficient in other cutting applications. One such application is cutting ceramic tiles. Below are some tips for using a spiral saw to cut ceramic tile.
Make Use of Safety Gear
In any kind of project that requires the use of power tools, it is best to use safety gear. Cutting ceramic tile using a spiral saw may cause pieces of the tile to fly over in any direction. Protect your eyes with safety goggles and wear gloves as well.
Do Not Cut Floor Tiles
The spiral saw was not intended to cut through floor tiles since it was initially designed to cut drywall. However, the carbide bit can be used to cut holes in a ceramic wall tile. To make a hole in a wall tile, mark the spot where you want to cut and allow the saw to cut a hole. Work the spinning bit around the hole in a clockwise direction to make a larger opening.
Do Not Force the Saw
The spiral saw is designed to cut objects with ease. Do not force the spiral saw to cut through a marked area. Let the saw do the work. Simply guide it to cut through the material.
Leave at Least 1/4 of an Inch of the Bit Exposed
Do not let the whole length of the bit through the hole. Leave at least 1/4-inch of the carbide bit exposed in order to avoid having the bit get broken. This also allows the bit to cool down easily.
Cut in Clockwise Direction
In cutting drywall, the cut should be made in a counterclockwise direction. However, in most materials, a clockwise direction is better. A uniform direction in cutting reduces chances of damage to the spinning bit. It also produces better cuts.
Use a Clamp for Uninstalled Tiles
When cutting a hole or opening in an uninstalled tile, make sure to secure the tile using a clamp. The spinning motion of the bit affects the stability of the tile so make sure to secure it with a clamp. The clamp restrains movement and allows you to cut an opening with ease.
Practice
The spiral saw is not a very complex cutting tool, but it may require some practice before getting a good grip of how to use it properly and professionally. To ensure that you make good cuts and minimize error as much as possible, a bit of practice will not hurt.
