8 Advantages of Using a Wheel Edger
A wheel edger is a useful machine for lawn maintenance. This handheld tool functions like a pair of scissors. When you push the wheel, it activates a star-shaped blade to pass by a stationery blade and clip the grass. It is useful when you need to trim grass that hangs on the lawn edge. Both manual and automatic versions of the tool are available on the market. Automatic models may be powered by electricity or gasoline. Whatever type you select, the tool generally assures you of several benefits. Below are 8 advantages.
1.  Ease of Use
The tool is one of the easiest lawn maintenance equipment to work with. The guide wheel on most edgers adds to the ease of use. No expertise is required to operate the tool. It is easy to accomplish maneuverability while you work which adds to job efficiency.
2.  Outstanding Performance
Overgrown grass can be a nuisance as it makes your lawn look less attractive. The edger is a simple-to-use yet highly effective tool to manage overgrown grass. It allows you to achieve a professionally groomed appearance for your lawn with ease.
3.  Increased Maneuverability
The wheels allow you to maneuver the tool with minimal effort. They provide guidance as you cut since they give a smooth ride. Wheels also transfer some of the weight off you while you work which causes less physical exertion. This also increases your productivity. You can trim corners, sidewalks, underneath fences, flower bed perimeters and other difficult to reach sites.
4.  Regulates Grass Growth
Certain grass species, such as the warm season grasses, can be difficult to manage. This grass spreads rapidly through the rhizomes. The tool can help you counter the advancement of fast growing grass. It helps you keep grass away from specific areas such as flower beds, sidewalks and driveways.
5.  Helps to Manage Flowerbeds
The rotating blade feature can help you dig a trench around your flowerbeds. When flowerbeds are surrounded by an angled trench it helps in water management. In the event of heavy rains, the trench will accommodate some of the water from the flowerbed. This prevents over-saturation. It contributes to the good health of the flowers.
6.  Low Maintenance
Lawn edgers are generally low maintenance tools. They do not break down easily and have a low wear and tear rate. This is partly because the tools aren’t exerted much due to the nature of work involved. With simple care the tools can serve you well for several years.
7.  Versatility
Most wheel edgers have adjustable blades. It allows you to select whatever angle you deem best for a particular job. You can also regulate the depth of cut from shallow to deep cuts. Many models also allow you to adjust the height of the machine. These features give you greater flexibility when you have to trim grass in different areas. It also increases efficiency of the job.
8.  Cost-Effective
The edger enables you to finish your lawn to perfection with minimal effort. You needn’t engage a professional landscaper to trim and finish the lawn for you. It helps keep your lawn maintenance costs down yet assures you of a a well manicured lawn.
