8 Most Important Pieces in a Rasp Set 8 Most Important Pieces in a Rasp Set
Woodworking is a craft where you will use a wide range of tools that include a rasp set to a table saw. Each tool has its own function, and in the hands of a skilled woodworker, can create amazing works of art. A rasp set is an invaluable package of tools that are used to perform many different sharpening, shaping, and sanding jobs. The typical shape of a rasp is a long steel bar with a curved belly that contains coarse teeth. These teeth are used to shape wood, plastics, foam, and even metal. They are much coarser than a file, but can do some sharpening when needed. In a rasp set, there will be different kinds for different jobs. Here are some of the most important.
1. Fine Cut Rasp
When you have some very fine detail work that needs to be done, then the fine cut rasp should be the one that you reach for. This rasp has teeth that are set close together and do not have as much of a cutting surface as other types.
2. Medium Cut Rasp
A little larger in size, the medium cut rasp is one that will be mostly used in a rasp set. You can do a lot of general work with this rasp from smoothing out curves on a cut you made with a jig saw, to deburring a metal cut.
3. Coarse Cut Rasp
When you have a lot of wood to carve, you will want to reach for the coarse cut option in your rasp set. This rasp has very large teeth with cutting edges on all sides. It is used for taking a lot of material off very quickly.
4. Tail Rasp
More commonly known as a round rasp, this specialty rasp has teeth like a normal, flat rasp, but is completely round. A great tool for smoothing bores, holes, and rounded sections of wood. If you work in woodworking for any length of time, you will find plenty of use for the tail rasp.
5. Knife Rasp
This rasp gets its name from its shape. The blade is knife like in shape with a tail rasp as a handle. A great rasp for working in small, thin areas like cut outs, slits, or slots in a bed frame.
6. Plaster Rasp
A plaster rasp is perfect for working with plaster, this rasp has a concave shape at both ends. It is perforated between the coarse teeth so that the plaster does not clog the working area of the rasp.
7. Cabinet Rasp
If you do a lot of customized work on cabinets, shelves, dressers, and other heirloom projects, then this is the perfect rasp in your rasp set. They have a flat surface combined with a rounded back. They are used for removing a lot of material, but in a small area. Great for planing and resizing openings.
8. Mini Rasp
One of the most often overlooked rasp in your rasp set is the mini rasp. This small, fine toothed rasp can help you in confined areas much better than a 12 inch rasp will.
