8 Upholstery Cleaning Tips 8 Upholstery Cleaning Tips
Upholstery cleaning tips are important to all homeowners who like to keep their furniture looking good at all times. Preventative measures and regular cleaning and care go a long way in preserving the beauty of your upholstery. Enlisted below are some useful upholstery cleaning tips.
1. Clean on a Weekly Basis
Make it a point to dust and clean your upholstery at least once a week. Clean more often if the upholstery is used most of the time. Use the vacuum brush attachment to remove dirt from all the corners and folds of the upholstery. Clean the back and legs as well to maintain a consistent finish.
2. Use Manufacturer Recommended Cleaners Only
All upholstery materials have a care label that indicates the cleaning material that is safe to use on it. Make sure you follow these instructions. If the recommended cleaner does not take care of a stain, have it professionally cleaned.
3. Test Any Cleaning Material before Use
Never apply any cleaner directly onto a conspicuous area on the upholstery. Always test a small amount of cleaner in a hidden area such as underneath the upholstery or the back of the legs. Incompatible cleaners can discolor or permanently damage the upholstery.
4. Tend to Spills Immediately
The best way to keep your upholstery in great condition is to prevent people from consuming food and drinks on it. But we all know that this is not always possible. When visitors come over or when the family is relaxing on their favorite couch, food comes into the picture and inevitably results in spilt drinks and dropped food. It is important to take care of such accidents immediately, before the upholstery and the underlying padding absorb the spilt matter. Blot the affected area with a clean paper towel. Never rub, as this will spread the stain. If this does not work, you will have to follow up with a dry cleaning solvent or a mild detergent. If you are using the detergent, apply the suds and not the liquid on the stain.
5. Rotate Cushions Regularly
To maintain an even look on the cushions, remove them every few weeks and rotate them around. This will prevent an uneven, pressed look. If cushion covers removable and the weather is favorable, leave the cushion padding out in the sun for a few hours as well. This will remove dust and bacteria from the cushions.
6. Ensure that Upholstery and Padding are Dry after Cleaning
After any cleaning session using detergent or cleaners, you must remove any remnants with cold water. Never use excessive amounts of water. Blotting with a moist towel is sufficient. After cleaning, air-dry the upholstery thoroughly. Moisture left behind can cause mold growth.
7. Clean Removable Covers Regularly
If your upholstery has removable covers, refer to the care instructions provided before cleaning. In most cases, washing the covers in cold water and then air-drying them is sufficient to remove dirt.
8. Use Professional Help when Needed
Once in a while, a deep cleaning by a professional cleaning company is good for your upholstery. This may also be required if there are some issues you cannot tackle yourself.
