9 Benefits to Low Voltage Lights
Low voltage lights are energy efficient lights powered by 30-volts of electricity or less. This innovative lighting system offers a lot of benefit and is widely used not only in homes but also in commercial and industrial buildings for its unique and brilliant luminance and cost-saving benefits. Aside from being energy efficient, low voltage lights also last longer than conventional light bulbs such as incandescent. When it comes to energy conservation, low voltage lights excel among other lighting options for the following reasons:
1. Energy Efficiency
Low voltage lights are highly energy efficient, especially when compared to incandescent bulbs. A low voltage light can emit as much light as an incandescent bulb using 20 percent of the energy used by the incandescent bulb.
2. Cost Saving
You can save a lot of money in your electricity bill using low voltage lights since low voltage lights consume less energy while providing excellent illumination in-door and outdoors compared to other types of lighting option.
3. Minimum Heat Contribution
Unlike halogen and incandescent bulbs, low voltage lights are cool to the touch and minimally contribute heat to its surrounding. This is very useful when installed indoors where heat sensitive plants are present.
4. Longer Life Span
Low voltage lights, especially LED lights, last 50 times longer than incandescent and halogen bulbs. This means savings on bulb replacement.
5. Safe
Low voltage lights are safer to install and use compared to other types of lighting. Low voltage lights use 12-volts of electricity via a power transformer attached to a standard 110-volts outlet. This means that you can install low voltage lights without turning off your main power supply. When installed outdoors, low voltage lights do not impose the risk of electrocution when exposed to rain or snow.
6. Versatile
Low voltages are relatively smaller compared to incandescent bulbs and other types of lighting. This means that you can install lighting to spaces using low voltage lights where incandescent bulbs cannot fit. Other than its size, low voltage lights are also excellent in giving your living space soft illumination that is pleasing to the eyes.
7. Worry-Free Security
You can easily install low voltage lights at the perimeter of your house without worrying about the electricity bills. Burglars are easily discouraged from entering a well-lit house compared to a house that is barely illuminated.
8. Environment Friendly
With the ever increasing demand for energy conservation, using low voltage lights is a great way of doing your part to help conserve our rapid depleting energy resources.
9. Easy to Install
You can easily install low voltage lights without the need to hire a professional electrician. When you purchase low voltage lights at your local home improvement depot, you also get a quick installation manual to guide you in the simple process of attaching the wires to a power transformer and attaching the low voltage lights in the wires. Since there is no risk of electric shock to be concerned with, you can install low voltage lights yourself safely.
