A Guide to Carpet Mold and Mildew Removal
If any of your home's carpeted areas have fallen victim to mold or mildew deposits, you should familiarize yourself with the proper method of carpet-based mold and mildew removal. With an informative instructional guide at your disposal, your home's carpets can be mold and mildew-free in no time. Below is a guide to effectively purge your carpets of mold and/or mildew.
Step 1 - Always Make Sure to Vacuum Your Carpet Before Cleaning it
One thing to keep in mind when preparing for the mold and mildew removal process is that you will need to vacuum the affected area before attempting to remove the above mentioned types of filth. With the aid of a vacuum cleaner, mini vac, or some combination thereof, vigorously go over the carpeted area until all the dust has been removed. As a general rule, the floor should be completely dust-free before your carpet-based mold or mildew can be removed.
Step 2 - Clean Your Carpet with a Homemade Cleaner
If you're not a fan of the plethora of chemicals found in most over-the-counter cleaners, you'll be pleased to learn that you can make your own homemade mold and mildew removal solution with nothing more than white wine vinegar and warm water. To produce this cleaner, simply combine two cups of water with one cup of white wine vinegar in an empty spray bottle. Once the ingredients have been added and your spray bottle has been sealed, apply the newly formed solution to any mold or mildew-laden areas of your carpet, then give it several minutes to sit. The white wine vinegar's acidity will subsequently loosen and lift the mold and/or mildew deposits, making them easier to remove from your carpet.
After the solution has had enough time to set in, use a sponge or washcloth to wipe any mold and mildew from the affected areas. Follow up by rinsing the freshly cleaned areas with warm water, taking care to promptly dry them, as moisture is one of the most common causes of mold and mildew formation.
Step 3 - Replace Mold and Mildew-Infested Carpet
If your carpet has any areas that feature exceptionally stubborn mold or mildew stains, you may need to replace the affected areas. This is generally a relatively easy process that can be carried out with a basic carpet repair kit. Start by using a carpet knife to extract the damaged area(s), then per the kit's instructions, glue on the replacement fibers and give them ample time to dry, after which your carpeted area will look as good as new. However, if the mold or mildew has spread to the flooring beneath the carpet, you may need to call in a mold and mildew removal specialist.
Step 4 - Keep Your Carpeted Areas Mold and Mildew-Free
Even after successfully carrying out the mold and mildew removal process, there are several things you can do to ensure that your home's carpeted areas remain safe. First off, make a point of promptly cleaning any spills because, as previously mentioned, moisture is among the leading causes of mold and mildew. Additionally, keep a watchful eye out for leaks in your home's ceiling or roofing, as these can lead to massive mold or mildew infestation.
