Adding a Home Office Space in the Basement
Home offices are becoming much more popular, largely due to the fact that more people are working from home or at least bringing work home with them from the office. If you don't have room on the main floor of your home for an office, the basement can be a perfect location. Not only is a basement a more secluded location, providing the quiet and privacy you need when you work, but there is often plenty of under-utilized space in a home's basement. Using basement space might also give you more options for creating a larger office than would be possible in the upper floors of your home.
Optimizing the Basement Environment
Basement spaces sometimes take a little bit of consideration in order to make sure they provide a comfortable living environment. Although basements are often cooler in the summer, making them pleasant, they can also sometimes be cold in the winter, or damp in the summer. Before doing any remodeling to add an office to your basement, make sure the area is dry and doesn't leak water. If your basement doesn't leak, but is simply humid, add a dehumidifier to the area to make it more comfortable. If your basement tends to be a little chilly during the winter months, add a small space heater to make your home office more comfortable. By optimizing the basement environment, any office you create will be more inviting and comfortable to use.
Decide if You Need a Building Contractor
If you want to actually frame in a room in your basement for an office, you might need the services of a building contractor, especially if you are not comfortable doing this type of work yourself. Before adding any room to your home, always check building code to make sure you are in compliance. However, in many cases, you won't really need to build a separate room for your basement office. You can create the illusion of walls by strategically placing furniture items to block out the area of your office. Instead of placing your desk against the wall, try using it to define the boundary of an imaginary wall for your office. Tall bookcases can also be used effectively to create the illusion of wall space, as can work tables. By utilizing these techniques, you can save money on building expenses.
Utilize Your Space
Although you might have plenty of room available to you in the basement, you should still utilize your space carefully to create a better office work environment. Sketch your floor plan out on paper, so that you can arrange items such as your desk, printer stand, bookcases and other furniture items to create good work flow. If you use a computer in your office, make sure you have proper electrical and network access in your new office space. Lighting is also a primary concern, especially in the basement where light is sometimes at a premium. Add a good overhead light, or use a desk lamp to make sure you can work in your basement office without eye strain.
Jessica Ackerman from WallDecorandHomeAccents.com generously shares everything she knows about wine home decor and metal tree wall sculpture.
