Adirondack Chair Construction: Using Resin vs. Using Wood
If you want to make an Adirondack chair, then you may be unsure whether it would be better to use resin or wood for your construction. This is not a simple decision, as what you use to create your Adirondack chair can affect its appearance, and will also affect how well the chair turns out, depending upon your abilities. Making these kinds of chairs is not easy, whatever material you make them from, so you may be more influenced by other considerations, such as appearance, cost, and skill level requirements.
Resin Adirondack Chair
The resin Adirondack chair is a relatively new invention. This material is designed to be sturdy and uncompromising, and this fits well with the solid, unbending tradition of the Adirondack chair. Using resin to create these kinds of chairs is a good idea if you are intending to use them as outside pieces, since the resin will be more weather-proof and stain-resistant than the traditional wooden forms.
They also need much less care than wooden furniture, as you do not need to varnish or refinish them every year. On the downside, resin furniture cannot be left out on hot days for very long, as this can cause the material to melt. It can also become very hot, which is not a positive thing in a chair. In addition, resin is not a traditional material for Adirondack furniture, and it may be hard to produce the home-spun effect of Adirondack in a plastic chair. While purchasing ready-made resin furniture can be expensive, getting together the kit to construct your own resin chair could turn out to be very costly.
Wooden Adirondack Chair
There is a reason why wood and Adirondack furniture go together so well. These chairs were first cut from wood around the Adirondack mountains, and so this material harks back to the very beginnings of this fashion in furniture. When you make a wooden Adirondack chair, you know that you are following a tradition which is well-established and that your furniture will be very attractive. Wood is also cheaper to obtain than resin-making kits, and much less intimidating to an amateur DIYer.
In using wood, you are letting the furniture look as it was intended. However, there are still problems with using wood for making the Adirondack chair. For example, wood is more vulnerable to the weather than resin, meaning that you have to adopt a yearly care-taking regime. This can be hard work, and will also take up a lot of spare time.
Wood can also suffer from other problems that are not found in plastics, such as insect infestation, or fungus. This can destroy a chair, which can be very disappointing after you have lavished care and attention on the project. Wooden furniture can also be very heavy, which is a consideration if you will be moving the chair about regularly.
