Adjusting your Retractable Hose Reel Tension
1-2 hours
Beginner
- 0-50
A retractable hose reel saves you time and effort while working in the yard. It also keeps your hose neatly coiled and protects it from exposure to the outdoor elements. To make sure your hose reel system delivers top notch convenience, it’s a good idea to know how to adjust the tension on the retractable reel.
Step 1: What Makes The Hose Retract
The hose retracts because of a large spring within the hose reel. The tension on the spring is preloaded at the factory, but it is possible for the spring to become un-tensioned or to have too much tension. This can happen from normal use, faulty parts or it can happen if the weight of the hose you are using is different from the hose size suggested by the manufacturer.
Step 2: Determine Factory Preset Tension
In order to adjust your particular model of hose reel system, you will need to consult the owner’s manual. It should tell you how many turns are needed for proper tensioning of your retractable hose reel. Keep in mind that if your hose is heavier or lighter than that suggested for use with your hose reel system, you may need to adjust the tension differently than your manual's recommendation.
Step 3: Prepare The Reel
If your hose reel system is mounted, you will need to remove it from the mounting brackets and lay it on its side. Use the screwdriver to unscrew the hub plate, but do not remove the plate from the hose reel.
Step 4: Adjust The Tension
With the hub unscrewed, place your socket wrench on the center hub nut and hold firmly. Note the factory preset and turn the hub nut the number of times recommended for your retractable hose reel. Increase the tension by turning the hub nut clockwise and decrease the tension by turning the hub nut counterclockwise. Do not increase the tension more than one turn past the factory preset.
Step 5: Putting The Reel Back Together
Once you adjust the tension on your spring loaded hose reel system, retighten the screws on the hub plate. If you removed your retractable hose reel from its mounting bracket to service it, attach it to the mounting brackets again. Test the tension by pulling out a length of hose and then retracting the it again. If the tension is still too loose or too tight, repeat the above steps and give the hub nut a half turn at a time until the proper tension is achieved.
A retractable hose reel is an investment in your garden hose as much as it is an investment for convenience. Follow maintenance procedures as outlined in your owner’s manual to keep it working properly. Should you need to adjust the spring loaded tension, the above steps should have it retracting smoothly in no time.
