Advantages and Disadvantages of a Wire Curtain Rod Advantages and Disadvantages of a Wire Curtain Rod
A wire curtain rod can enhance your indoor décor remarkably. With the wide variety of wire rods available on the market, you’re bound to find something that meets your needs in the wire range. It is a viable alternative for homeowners who are looking for something different from the usual vinyl or wood. Homeowners are spoiled for choices with the various types of curtain rods on the market. Below are the advantages and disadvantages of wire rods to help you make a choice.
Advantages of a Wire Curtain Rod
Wire curtain rails are amongst the most affordable available. No matter how many rods you may need to install in your house, the overall budget tends to be manageable. This helps you attain your desired indoor décor without too much of a financial strain. The rods are available in a wide variety. You’ll find them in aluminum, brass, copper, stainless steel or wrought iron. This gives homeowners greater freedom when it comes to selection. You can get rods with decorative end-pieces to enhance the beauty of your room. Those with a sparkle can add a delightful touch to the room.
A wide range of accessories is also available for wire rods. This helps you achieve your desired indoor décor as well as enhance room ambiance. Wire rods lend style and elegance to any room and blend well with a variety of architectural styles. Whether you need to furnish an old-world house, a cottage or a more contemporary dwelling, you’re sure to find rods that will do the job. The flexible nature of wire allows rods to be curved or cornered according to need. This allows you to install your draperies with greater freedom.
Wire curtain rods are light which makes installation easy. Not much labor or time is required to fit the rods. This helps you keep costs down. The high durability of wire curtain rods also adds to their popularity. They’re among the most durable on the market. They don’t easily break or chip. During installation, if bending is required, you needn’t worry about damage to the rod. When moving becomes necessary, the rods can easily be detached and used again in a different location. Wire curtain rods are also low maintenance. They don’t require much care once installed yet will serve you well for several years. Finally, you can count on added value to your home when you opt for wire curtain rods.
Rust may be a problem especially if you live in a high humidity area. Corrosion can also be a problem especially for those who live close to the sea. If not treated, the rods may loose their smart appearance quickly. Replacement may become necessary which will add to your costs.
If you intend to hang up lots of heavy draperies, this may exert pressure on the rods. They’re better suited for lighter draperies as these will not cause the rod to sag especially in the middle.
