Advantages of a Low Flush Toilet Advantages of a Low Flush Toilet
There are several advantages to a low flush toilet that make it a worthwhile investment to any homeowner. When you are considering new fixtures for your home remodeling project, or when you are picking out fixtures for a new build, you want to pick the most modern units because they offer cost and environmental advantages. Before you decide on bathroom fixtures, it is important to understand the advantages of a low flush toilet over a standard toilet. Put the advantages and disadvantages side by side to see if the investment is worth it.
Less Water, More Savings
A low flush toilet is designed to use less water per flush. The newer toilets use only 1.6 gallons per flush. This is a significant difference over previous models that used between 3.5 and 7 gallons per flush. This means that the average family will save $100 per year in water costs over the older style toilets. Over the course of a 30-year mortgage that would equal a savings of over $3,000 in water bills for a homeowner.
Environmentally Friendly
Because of the way low flush toilet conserves on water, it becomes environmentally friendly. The average family of 4 using a newer toilet would save almost 22,000 gallons of water every single year over using an older model. Over the course of a 30-year mortgage that family would save over 660,000 gallons of water. That is less water being flushed into the sewage system and more water available for drinking and farming. With the water shortage that is starting out in the western United States, conserving water is a prime concern. If one family can save 22,000 gallons of fresh water a year by using a low flush toilet then an entire community could save millions of gallons of water a year.
Small Size
The tank on a low flush toilet not only uses half the water that an older model uses, it is also half the size of an older tank. One of the newer toilets can fit into a smaller design space and open up more remodeling possibilities for you in your bathroom.
Complies with Water Conservation Laws
In the western United States and in the mid-west deserts, in 1992, there was a series of legislation passed that outlined guidelines for citizens use to conserve water. That is around the time when low flush toilets became popular all over the country. Low flush toilets help consumers adhere to laws that you may not even know existed. If you do not have a new model toilet, then you should talk to your local zoning board to see if there are any regulations that stipulate you install a new model toilet.
Popular
As the technology surrounding low flush toilets advances, they are becoming the default standard in the plumbing world. When they were first introduced, they lacked the flushing power that consumers were looking for. But plumbing advances have created low flush toilets that can operate in the same way that the older 7 gallon models used to operate. Not only are the new low flush toilets cost effective, they are also becoming the standard in the plumbing industry.
