Advantages of Finishing Block Walls with Bonding Cement
Using a bonding cement to finish block walls is a very smart idea. If you are working on this type of project on your home, here are a few reasons why you should use a bonding cement to finish up:
Smooth Finish
A great look is one big advantage to finishing your block walls with bonding cement. The holes are filled in and the finish makes it look complete and sleek.
Strong Foundation
Bonding the block wall together keeps it sturdy and safe. It not only makes the wall stay together, it also keeps more delicate parts of the wall together by leaning on and distributing the weight with others. The adhesive also helps to keep everything secure no matter what type of weather there is.
Cost Efficient
While you are spending a little bit more money up front to buy the bonding cement, you will save money and effort in the long run. By finishing the block walls with bonding cement, you will find that the wall stays up longer and experiences less damage. This leaves you with less fixing and repairing or replacing to do. You can also do this yourself so you don't have to hire someone like you may in other projects.
