Advantages of Stamped Concrete Flooring
Stamped concrete flooring is a popular flooring choice for outdoor areas like patios and pool surrounds. Consider the following benefits of this type of flooring to determine whether it is right for you.
Cost
One of the benefits of this type of flooring is that it can achieve realistic looks without costing as much as comparable types of flooring. For example, you can make your concrete look like slate tile without actually having to pay the high cost of slate tile installed. This can save you a great deal of money if you are doing a large area.
Slab
Another benefit of this type of flooring is that it is still a slab even though you can make it look like smaller pieces. When you have small pieces of tile, you have to worry about cleaning the joints between them. With stamped concrete flooring, you should be able to use a power sprayer on all of it. This will make the process of maintaining your floor very easy.
Traction
Stamped concrete flooring naturally offers traction under foot. Instead of having slick, smooth concrete, you will have a textured surface to work with.
