Advantages to a Reclaimed Wood Floor
Reclaimed wood is a type of hardwood that is taken out of old homes and barns or taken out of rivers and lakes. This type of wood is commonly made into wood flooring. Read on to learn about some of the advantages that you can get by using reclaimed wood flooring.
Eco-Friendly
One of the biggest advantages of using reclaimed wood flooring is that it is environmentally friendly. This wood flooring is created from sources that does not require trees to be cut down. With other types of wood flooring, manufacturers have to cut down many trees to support production. With reclaimed wood flooring, it is basically like you are recycling.
You will be able to make a significant impact on the environment by not relying on fresh cut trees. Considering the fact that it takes many years to grow new trees, it can be very difficult to replace all of the trees that are cut down for wood flooring.
Durability
Another big advantage of reclaimed wood flooring is that it will often be more durable than what you can find from other sources. Most of the reclaimed wood flooring is considered to be old-growth wood. This was made from trees that were allowed to grow for hundreds of years in some cases. When a tree is allowed to grow this long, it becomes denser and harder. If you are interested in hardwood flooring, you want it to be made out of wood that is dense because it is less likely to scratch and dent. Reclaimed wood flooring is generally much harder than the regular wood flooring that you can buy.
Looks
With reclaimed wood flooring, you will also get a product that has a beautiful look to it. Many people prefer to the look that reclaimed wood flooring can provide over traditional wood flooring styles. This type of wood tends to provide a very rustic look to any floor or furniture. This is especially true if the wood was already used in a barn or an old house. It will have a great deal of character attached to it which is very attractive to a lot of people. Even though several types of the newer hardwood that is produced tries to replicate this look, there is nothing quite like the real thing.
Cost
When purchasing this type of hardwood flooring, you might also be able to save some money. This is hardwood that does not have to be harvested through the traditional methods. This means that the wood flooring mills can often purchase this type of hardwood for cheaper than they would be able to from other sources. When the mill can purchase it cheaper, they will often be willing to pass these savings on to the consumer by charging less per square foot for the product. This will essentially allow you to buy a more durable, rustic floor for less money than buying new.
