Advice for Your Tuck Pointing Project Advice for Your Tuck Pointing Project
Tuck Pointing is a masonry technique and is used as a part of brickwork repairing. Basically, it is a method that is used to repair the mortar lining between the bricks. It is often used to repair cracked surfaces like chimneys. It is also used to repair other surfaces when holes or small cracks begin to appear. Tuckpointing projects are easy to do and require basic tools. Here are a few tips to make sure the project is completed properly.
Tuckpointing Basics
Tuckpointing allows the original brickwork to remain undisturbed. The main objective is to avoid causing additional damage. The repair process should not increase the pressure on any of the bricks.
Tip 1—Getting Started: Determine Damage & Basic Safety Measures
Before you begin any tuckpointing project, you must properly estimate the extent of damage that needs repairing. For small cracks or holes, the mortar repairing will not require too much work because there is only a small chance that the extent of the damage is extensive. However, if the significant damage is visible, large-scale removal of mortar will be necessary and you will need to be cautious. This type of repair usually occurs in brickwork where there is aging mortar.
Next, you should wear protective clothing, such as long sleeves, pants and a face mask. Also, wear goggles to protect your eyes from any debris.
Tip 2—Choosing Appropriate Tuckpointing Tools
A tuckpointing project should always begin with basic tools like a mason trowel, tuck pointer, mortar mixture and a mist sprayer. Also, it is very important to have proper dust and debris-removal tools and other tools like a chisel and a hammer. These help to easily access the mortar joints and remove mortar without damaging the surrounding bricks. Jointers are sometimes needed to provide a finished appearance to the refurbished mortar linings.
Tip 3—Using Tuckpointing Tools Properly
It is best to wet the repair surface after removing the mortar and debris. This will help the mortar bond better. Also, be sure to spray water to ensure the new mortar lining does not crack. Spraying water with a misting spray bottle is the best way to spray to avoid cracks. Prepare the mortar-mix with care. When you begin to mix the water and mortar, ensure that you add the water slowly. You must continue to mix the mortar to ensure that the mixture does not harden. Use a thin, long-pointing trowel for pushing the mortar between the bricks. The trowel is also useful to smoothen the freshly-applied mortar. Allow the new mortar to dry for about five hours.
Other Tips
  • It is best to complete this type of work in good weather conditions. Freezing or frost conditions can severely compromise the integrity of the repaired mortar lining.
  • You can brush along the brick joints as the new mortar is curing. This helps to blend the new mortar along the older bricks and helps to create a uniform appearance.
