Affordable Ceiling Options Affordable Ceiling Options
If you're looking to redesign your home, one way to distinguish a room is by considering different ceiling options for those spaces. Ceilings of different types can dramatically alter the amount of light, the general appearance and the overall feel of a room or a home. Fortunately, there are many different types of ceiling options to choose from, many of which are quite reasonably priced as well.
Bamboo Panels
One of the most effective and unique ways of patterning your ceiling is with panels made from bamboo. These panels are oftentimes made from recycled materials and are therefore quite inexpensive and good for the environment at the same time. Additionally, bamboo is a very plentiful resource, meaning that the material used for the job is inexpensive. Bamboo doesn't provide a great deal of durability or sturdiness, which makes it an ideal choice of material to use on a ceiling panel; the ceiling is much less likely to be damaged than other surfaces in the house, where people are likely to walk or place objects.
Ceramic Tiles
Ceramic tiles are a great choice of ceiling material as well, particularly in bathrooms and kitchen spaces. These tiles have the benefit of being available in a wide array of designs, colors and shapes. This means that you'll have no trouble coming up with a tile pattern for your ceiling that is perfect for your design aesthetic and sensibilities. Tiles are also quite durable and sturdy, capable of withstanding a great deal of exposure and other damages. They are generally easy to install, but setting up tiles on the ceiling is a bit trickier, so this is a consideration to keep in mind.
PVC Panels
One of the most popular types of ceiling material in recent years has been the PVC ceiling panel. PVC ceiling panels are excellent in terms of long-term durability and longevity. These panels are resistant to heat and water damage, scratching, cuts, and other types of damage that can occur as well. On top of that, a customer response to the plain PVC paneling that wasn't particularly favorable has prompted manufacturers of these panels to create a huge array of different colors, patterns and designs for their ceiling paneling. This gives you a wide array of choices to select from, ensuring that you'll find exactly what you need for your do it yourself remodeling project.
Gypsum Tiles
If you live in an area that gets high levels of humidity, vinyl laminated gypsum tiles are one of the best choices that you can make for your ceiling while staying within a reasonable budget. These tiles are resistant to damage that affects many other tiles, including ones on this list. High humidity areas are notoriously difficult on ceilings, and gypsum tiles are one of the best types at resisting this damage.
For more information, speak with a professional in your area.
