All about Vinyl Composite Tile All about Vinyl Composite Tile
Vinyl composite tile, also referred to as VCT, is a good option as a flooring material. It is relatively affordable, while also being resilient. These tiles are a very versatile alternative, and they can be found in a wide variety of colors and patterns. They are also easy to install and maintain.
Composition
The main composition of a vinyl composite tile is essentially vinyl and PVC. Then a number of fillers are added to make up the final color of the tile.
Variety
Vinyl composite tiles are available in various colors and shades. They are also given particular textures and patterns, so as to meet a larger market. There are even manufacturers which produce VCT tiles which look like stone or even parquet.
Cost
When compared with other flooring options, VCT tiles are very affordable. As a result their popularity increases, because apart from being quite cheap, they are also hard wearing.
Installation
It is not difficult to install vinyl composite tiles yourself. As a result you will save further, as you will not have to hire a professional to do the installation for you. These tiles can be easily cut with a utility knife, and simply require adhesive to be attached to the floor.
Maintenance and Cleaning
Vinyl composite tiles are fairly easy to maintain. It is important to regularly clean them, simply by sweeping on a regular basis, and wiping with a soft, damp floor cloth or mop. To improve its gloss you can apply some high gloss VCT floor sealer from time to time.
