Alternatives to Aluminum Downspouts
Though most homes are built with aluminum downspouts as the way to drain water off your roof, these spouts can easily become clogged and difficult to clean out. Therefore, you may be interested to find out that there are several other options available to you that may work far better than your current system.
Copper or Stainless Steel Downspouts
One alternative to the aluminum downspout is a copper or stainless steel downspout. Though these options may be more durable that the aluminum version, leaves and other debris can still clog the downspout drains and cause water buildup on your roof which could cause additional damage. If you decide to go with one of these options, know that you should do all you can to make sure you have the smallest number of elbows in the drain possible. This will give you the best possible chance of your drain not becoming clogged.
There are also options to run drains through your home as opposed to outside. If you do this, you will need a durable material, such as stainless steel and will need to make sure that it is well maintained so that you do not experience flooding in your home. This option is not the best as there are many potential problems.
Rain Chains as Downspouts
Rain chains can also be used to help rain water run down to the ground. These hang from the top of your roof where the water usually collects and drains and will slowly allow the water to drip or run down the chain.
There are some problems with this system that you should be aware of, however, as having chain drains can be difficult to install or be harmful to your health. Because the chain hangs from your roof, it can sometimes be difficult to find a way to attach it to the roof and can fall down easily, possibly causing damage to the roof. Also, as the rain comes down the chain it could cause it to rust which could potentially cause health problems. Children can also grab hold of them and hurt themselves by falling off.
The good thing about rain chains is that there is no clogs that are impossible to clean out as the leaves and other debris will simply fall on the ground.
Rain Cups as Downspouts
One of the best methods for a downspout is to use rain cups hung from the roof. These will allow the rain to fall in a controlled matter and will also give a unique style to the exterior of your home. There are several styles to choose from that you can enjoy. Made from stainless steel or copper, these rain cups are designed to not rust or mildew, which is beneficial to your health and will help from the cups system to become useless.
As with the rain chains, rain cups will not become clogged with debris, and even if they are, they will be easily cleaned out by letting the leaves out of the cups.
There are several options available in addition to aluminum downspouts and you should select the style that works best for you.
