Aluminum Soffit Installation: 3 Tips
When it comes to installing an aluminum soffit there are a few things that you will want to keep in mind. Here are some quick tips to help you through the process.
Tip 1 - Prepare the Old Roof
You have to make sure you start out the project by removing the old gutters as well as any other old material that needs to be built onto. The most important part of this step though is to make sure that you get anything that was old or moldy out so that it doesn't continue to spread or grow.
Tip 2 - Use the Right Tools
There are a few tools that are necessary when it comes to this kind of work. Tin snips are a must for cutting as well as a jigsaw. You will also want to make sure that you have a hammer, folding tool, trim nail punch, utility knife and carpenter's square.
Tip 3 - Watch the Nails
While it may not seem like a huge deal, you want to make sure you watch what kind of nails you use. The best bet are 1-and-1/2-inch aluminum nails. You can also find the nails that are the same color as the material to make it look sleek.
